- Replies 9
- Views 3.3k
AH64ID 3 posts
dorkweed 2 posts
dieselautopower 1 post
volkswagon 1 post
My Pricol pyro started acting up this past winter, and after a few tows with it acting funny it was time to give it the boot. I really wanted a matched set, so I sold the other 4 Pricol's and ordered up a set of 5 ISSPRO EV2's.
I have been wanting to change the locations of my a couple gauges and add a time delay relay for a while, so this worked out well.
I had the alarms set to where I want them, which is a GREAT feature of the EV2.
Boost 0-40, warning > 38 psi
EGT 0-1600°, warning >1300°
Fuel Pressure 0-20, warning <3 psi
Oil Pressure 0-100, warning <15 psi
Exhaust Backpressure 0-100, warning >65 psi
The gauges came with the dimmer and that made install VERY easy. You are able to daisy chain them, and I was able to route the wiring from the dimmer knob to the Oil in the A-Pillar, to EGT, Boost, Fuel on the dash and down to DP by the trailer brake controller.
Previouslly the EGT was in the A-Pillar, and Boost/Fuel/Oil were on the dash, with DP down by the brake controller. I liked DP by the controller as I mainly use it for the exhaust brake, and next to the brake controller made sense. What I wanted to do was put Boost/EGT next to each other on the dash and move oil to the A-Pillar.
Additionally I have been wanting to add a time delay relay to the gauges. I don't like how when you start the truck the gauges reset and readings have to wait on the gauge to power back up. I got a TDR from a friend of mine, and wired all 5 EV2 to it. Now the ignition has to be off for about 2 minutes before the gauges shutoff. This does 2 things I like, it allows quicker and more accurate oil/fuel pressure readings during and after start and it lets me monitor EGT's after shutting the motor off. If they really climb I can tell I didn't allow enough cooling time.
All in all I like the EV2's. I still think some of the markings on the Pricol's were better, and a mechanical boost gauge is much smoother than an electric one. The boost gauge does read about 1 psi lower than the ECM sees, but I think that's due to being at 3K feet elevation. But overall these are great gauges, and very precise!
