power steering and vacum pump
- Replies 9
- Views 3k
Haggar 3 posts
Mopar1973Man 2 posts
dripley 2 posts
War Eagle 1 post
I noticed a little growl out of my power steering pump today. Checked the fluid and it was low and added some to it quit the little growl I was hearing. I have also noticed it growl a little on start up in the cold part of the winter. It always went away after warm up. How do you check the pump to see if it is going bad? I have also noticed some oil driping from that area and was thinking the seals are going bad. When I get home I am replacing the tappet cover gasket and will have that side of the engine pretty clear. Since I am going to be in there that deep I would not mind doing what ever I need to wile I have it apart.I have seen mentioned here before about a rebuild kit for the seals. Can yall remind me of where that can be obtained?
