- Replies 11
- Views 7.4k
fire176969 3 posts
Mopar1973Man 2 posts
Haggar 2 posts
hd99fxr3 1 post
My neighbor is selling his 2001 3500...I put a injection pump and lift pump in it for him a couple of weeks ago...While I was test driving I noticed the A/C was not working...I tried giving it a charge with one of those quick charge bottles, with the built in gauge in it. There was a low charge, I brought it up to spec for the temperature. But it still is not blowing cold. I also noticed that the compressor is kicking off and on rather quickly, It builds pressure fairly quick, then kicks off right away...which is common if there is a low charge....Thinking maybe the high pressure switch is bad? Any other ideas?? Thanks
