Put on new tires and noticed a pronounced pull to the left. Checked the tie rod ends and found both sides with some play in each side. Is there supposed to be any play in them? Am approaching 100k miles so I guess I need to get new tie rod ends??? Just came off a 1200 mile trip and am not sure if I noticed the pull to the left with the old tires or not, if so, it was not as pronounced. I had the new tires on the left side switched to rule out a faulty tire. It still had the strong left pull.
