- Replies 8
- Views 2.5k
Haggar 3 posts
Rogan 2 posts
98whitelightnin 1 post
GSP7 1 post
I was told by my mechanic that put my tie rod ends on that I need to replace the right side upper control. Found that a replacement control arm is around $345.00 (ouch). He is going to try to replace the bushings and see if might solve the problem. Anyone care to share any information or personal experience in this area? I think he said that he had the front end up and had someone mash the brakes and he could see movement in the control arm. Also, when you are driving and apply the brakes you can hear a noise and feel a bit of a jerk in the front end.
