- Replies 9
- Views 2.7k
Mopar1973Man 2 posts
rickf 2 posts
gassernomore 1 post
hex0rz 1 post
Alright the other day, I noticed a drop in fuel pressure. Its been a continuous thing since then. It will now run at 15psi instead of 20 at idle. I did not mess with the pressure regulator or anything else of that nature. I have less than 10k miles on the fuel filter.I'm worried that if it is not the fuel filter, it could be the airdog pump going out, AGAIN...I will have to check the fuel pressure gauge and make sure the connections are still good and air is not getting into the system.I use permatex thread sealant, its really sticky stuff and says it wont be dissolved by fuels. If this is my problem, anyone have any suggestions about what sealant to use on the connections?Or is there another reason why my fuel psi is dropping?
