- Replies 40
- Views 10.3k
Mopar1973Man 9 posts
ISX 6 posts
guesswho512 6 posts
gassernomore 4 posts
Ok Gang... I'm looking for a bit of help on diagnosing a charging issue. Been a busy day for fire calls today and on my way home from this last fire call I was noticing on the SG II my charge voltage is low and erratic. It still within spec of 13.5 to 14.5 volts but it bouncing a bit. With my lights all going its hover right at 13.5 to 13.6 which is usual for a charge voltage. Then it might bounce up to 14.0 to 14.1 then fall again... My first though is field brushes are wore out... Still running stock batteries 8 years old... No codes either... Now here is the kicker I need to do this without throwing a ton of money at parts guessin' I don't want to blow my Christmas Cash on repairs now... HELP!
