I have a 1999 2500 24 valve.. Approx a year and a half ago I replaced the injection pump with a remaned one from thoroughbred diesel and a fass ddrp lift pump. About 3 weeks ago I fired up my truck after it was sitting for about 2 hours. I drove about a block and it started spitting and sputtering. I opened my water valve on the filter housing and air came out then fuel. It fired up and ran fine after that and was back to normal for a day or two. It then did the same thing again and I again opened the valve and air came out, it then fired up and ran fine. Now it's happening every time I go to drive it. There are no codes and my life pump pressure is superb at 15 idling and 13 WOT. It starts fine. I let it warm up. Listen for it to start running rough, turn it off, bleed the air, fire it up then drive it as long as I need with no problems. I also have just turned the key on and opened the valve before ever starting it and it blows fuel out with great pressure. So it only sucks air when it is running. I can not find any fuel leaks anywhere and my gas cap appears to be functioning properly ( judging by the air pressure when I open it).
