Vacuum pump - Rebuild time!
Hey Gang...Just to skip hunting over the site I know you guys can spit out the place to get vacuum pump rebuild kit. Mine is finally starting to leak engine oil and getting the side of the block hosed with engine oil. Not enough to drip on the floor of the shop but it won't be long. So could you point to the information on the vacuum pump rebuild kit and any helpful hint would be great.
  • Replies 45
  • Views 16k
Got a free moment to crawl under the Cummins with my camera and shoot a picture of the leaking area.
attachicon.gif4748.attach
Is this the first time you're doing this on your truck? How many miles you got on it now, just trying to see how often this needs to be done. What if a guy changed fluid more friqwent would that prolong life of these seals? Just wondering.
As far as I know you just pull the vacuum pump and PS pump as a unit from the truck.
Ya but, what about the VP? If you're doing the KDP at the same time, same answer?
You won't need to touch the VP if you are going to tab the KDP.
