Awapping VP44 & side cover gaskets
- Replies 10
- Views 2.2k
Yankneck696 4 posts
Mopar1973Man 2 posts
dripley 2 posts
98whitelightnin 1 post
OK, my side cover is leaking about a quart a day. Have new gasket set. Also have a used VP44HO to put in(Thanks Ghostman). Have big line kit from stock filter with FP sender for my Quad & gear puller(Thanks Jkidd).Going to pull VP, all lines, filter canister & frrp. Then, I am going to pull the ECM & possibly space it out or at least plan it out for the future. Then, do the leaky side cover gasket.I will pull apart the FRRP & reseal it while i have it out. I also have a NAPA 1/2" 50 micron filter to put in before the FRRP.Here's my questions:1. I do not have the barring tool, so is there a redneck way for breaking the IP gear nut loose & torquing it without the barring tool?2. Cleaning the shaft is easy. Should I just use a rag with braklean on the inside of the gear?3.Should I BLUE locktite the IP gear nut if I cannot reliably get the needed torque?4. can I use my remote starter button on the starter with the key on (no assistant to crank over to bleed IP lines?I do have a new fuel filter, oil, oil filter, intake horn gasket (also tapping intake horn to 1/8NPT-27 since I have the bit & tap from my EGT install in 2 places & plugging them with brass plugs). I have new silicone adapter boots & reusing old clamps (replacing other side also if not needing heroine for my back when done).Anything anyone else can think of?I have read 3 different tutorials.Thank you,'Ed
