- Replies 17
- Views 3.4k
inline6power 9 posts
Mopar1973Man 3 posts
98whitelightnin 2 posts
skipetex 1 post
on my 99 dodge p pumped truck i am having a major issue. 2 days ago i go to start the truck up and all the guages stopped working except the fuel gauge and speedo. Oil, tach, volt, temp all are on zero. ac does not work either. after driving the truck for say 5 minutes, all the gauges kick back on and the ac starts to work. i have checked all grounds, power, and fuses and everything seems inline. this mornign i drove it for 10 minutes and the gauges did NOT come back on. also cannot check for codes as the scanner will not connect to the truck now. weird part is it does not say NO BUS in the odometer. sometimes the scanner will work and most times it will not. only codes i have been able to pull other than the fuel injection pump stuff since its no longer there is a grid heater relay. not sure where to check or what to check. any help is GREATLY appreciated. thanks.
