Excessive Black Smoke on Acceleration
- Replies 19
- Views 31.9k
StewB 6 posts
Mopar1973Man 3 posts
CSM 2 posts
CUMMINSDIESELPWR 2 posts
Well, it appears I have a new issue with my truck. Under acceleration I get a fairly thick cloud of black smoke along with sluggish acceleration. The harder I mash the pedal the worse it gets. It rarely ever smoked before unless I turned the Minimaxx up and romped on it. Even then it wasn't near as bad as it is now. Some background:I've just moved from Alaska to Utah. I drove roughly 3500 miles with a gross weight of 22,000 pounds. Minimaxx was set on the Tow setting (+60hp). At the beginning of the trip the temps at 65mph on relatively flat ground were as follows:Ambient 60*Coolant 195-200Tranny 170-180Egt 900-1000When I got to Washington state the temps were sitting atAmbient 95Coolant 210+Tranny 190-200Egt 1000-1050During hill climbs, of which there were 100's, my egt (pre-turbo) would climb well into the 1300's and occasionally briefly spike over 1400. I was a little concerned about the temp increases, particularly the coolant, but attributed them to the rise in ambient temperature. We picked up a car in Seattle and my wife told me at our first rest stop that I was blowing more black smoke than normal. She's followed me a lot before so I trust her opinion on this. I attributed that to being about 5,000 pounds heavier than ever before and having to lay into the throttle more; however now I'm not sure I was right. Now that we are in Utah and empty again it is still blowing excessive black smoke, even under light acceleration. The turbo also seems to take too long to spool up. It's well into the 90's here and I've never driven this truck in temps warmer than 80* mostly under 60, so I don't know what to expect in a hot climate. The truck is very sluggish for 2-3 seconds from a stop but seems ok at cruise. I haven't even run a full tank through yet so I don't know my current mpg. I got 9.8 mpg on the trip. I've read some possible problems could be bad/dirty injectors, dirty air cleaner or MAF, or problems with the turbo. Worst case was a melted or deformed piston. Any opinions on where I should start? I eliminated the air cleaner and MAF.I can provide more info but don't know what else would be helpful. Thanks,Stew
