- Replies 16
- Views 9.3k
texas_outlaw 7 posts
ISX 3 posts
JAG1 2 posts
dennhop 1 post
Truck is a 97 2500 4x4, swapped in a nv4500, retained the auto PCM and grounded NSS wire. Speedo did not work on the initial road test, shut the truck down at the house and an hour later we took the truck on another road test and everything was working normal. After two days of driving normally I parked the truck in the driveway, came back out 30 min later and when I keyed on there was only oil and air bag light prove out. No engine, gen, wts, trans temp or wif lights come on during initial key on for prove out. A/C is not working, alt. not charging and tach is dead. All other gauges work properly and read normal. I have replaced the ESS and gapped at 0.050", all fuses in the cab and under hood have been checked with test light and dvom and all are good. Battery connections removed and cleaned, grounds all seem to be making good contact and power is present on other side of fusable links. When the problem first started I removed the 20amp fuel system fuse under the hood with the engine running and the alt. started charging(overcharging after a min or two) and a/c compressor stayed on no matter what position the selector in the cab was at. We pulled the harness this weekend to inspect and found no issues. I found a connector pinout for the pcm connectors but the circuits are hit and miss with whats on my truck. I have no diagram to follow but, as far as i can tell my constant and switched 12v are present at the pcm as well as the grounds. I can ground the individual circuits for the wif, eng., gen ect. and the lights illuminate in the instrument cluster. Sorry for the book but any help is very much appreciated.
