PacBrake question
I am buying an inline mount setup. I am running a aftermarket turbo and am thinking I need to get a shorter outlet on the turbo to make room for the brake. It has six bolts and it comes off the housing. So then I can clamp the brake to the turbo and the downpipe to the brake without hitting the firewall. If anyone has tips or a picture of their setup that would help a lot. Thank you.post-12379-138698210232_thumb.jpg
  • Replies 47
  • Views 11.3k
My banks has about a 1.5 second delay built into it. There is a reason for that but it eludes me for now.
The Pacbrake has that too since I used the ECM to control it.  I would have to say it is about the same.  What I meant was when the brake engages it takes about 2 seconds to build pressure since it has the downpipe to pressurize.  That's was my impression when I drive it anyways.
Mine is in the elbow attached to the turbo and is pretty instantaneous when you let off the gas other than the 1.5 second delay. The Banks came with its own little brain.
Edited by dripley
Wish I even had one.
They are nice. Whether you are towing or not.
Interesting, I didn't look at banks at all.  It was between BD and Pacbrake for me.  My memory is a little fuzzy, but a long time ago I was watching a video and the exhaust brake cycled on and off a few times when he started the truck.  I wanna say it was a banks.  I do not know if that was owner or is that part of the computer system to keep the brake operational?  Correct me if I am wrong.
They sell em everyday LOL.  I never thought I would have one.  I never needed it, but after a couple years of towing the bigger trailer I am looking forward to having it this summer for going to car shows and camping.
The delay is to allow the boost to drop and the turbo to slow down before plugging the exhaust off.
It also allows for shifting with the switch on.
Then your about right for delay for the Jacobs brake that is ECM controlled. Too bad its not based off of throttle control so you could still row gears and then just release your throttle foot for braking.
What do you mean? I can have the brake switch on and row gears without it coming on.
Yes. I can leave mine active and row gears never have the brake engage unless I delay 2 seconds then it will. So I could for example know I'm coming to a stop gear down and leave my foot of the throttle and have it engage right after the downshift.
If I want instant on. I got to be coasting for long periods but leave the throttle alone but control the brake with my thumb switch on the stick and the brake is instant because the delay has already been meet because throttle IVS (Idle Validation Switch) has idle switch set over 2 seconds.
Yea, they are made every day, BUT to install one PROPERLY I would need to change exhaust springs and get some kind of controller for the transmission. It would get rather expensive real quick. Since I am no longer working and I am on a fixed budget then it gets to be a luxury.......I have thought about making one though........
I've never noticed a difference, thou I haven't ever payed attention to coast vs drive to brake time. I will now.
The banks comes on at every cold start and cuts off around 140*. Helps the truck warm up faster. A banks selling point was that it exercised the mechanism to prevent it form freezing up. I leave mine on all the time and it gets all of that it needs. The warm up feature is nice.  I believe a lot of them have that feature.
The man reason I got the Banks was because I already had the Banks quick turbo, power elbow, and 4" exhaust. All I had to do was unbolt the elbow and bolt in the brake, very simple install.
While the banks has it own little brain, it is tied into the TPS so any throttle keeps it off and it is tied to the ECT sensor for shut down at 140 on a cold start.
The e brake s right up there as one of the best things I have added to my truck.
Why would you need to change the exhaust springs? I did not think the brake generated enough pressure for that. I dont know that for sure, just asking.
You generally don't have to on the 24 valves, but the weaker springs on the 12 valve engines require an upgrade.
12V trucks came factory with lower pressure exhaust valve springs, IIRC around 30lbs.
Looking at he mods in MnToms sig and his power I would have thought he had them. They are needed if drive exceeds 30psi.
If you make one, make sure to let us in on the build.
I noticed this too.
Far as I know I have stock springs. I don't have the stock turbo though. I have an HX with what I was told "an updated exhaust housing" by the guy who did the work. I don't know how many of you remember Piers Harry, but he is the one I got this turbo from. I can hit 40+ psi booost with the probane if I want. I have no idea what the drive pressure is on it.
HX35? If so then your drive is going to be above 40. I would verify those springs if your hitting that much boost. A valve touching a piston is $$$
I don't normally go anything above 30PSI even towing, but I haven't had any problem with it in the last 140,000 miles so I should be OK. Most of the time I am running way lower PSI boost than using the HY, but like I said, it has a better exhaust housing.
Edited by MnTom
