- Replies 10
- Views 11.1k
scummins 3 posts
JAG1 1 post
NWMontanaMan 1 post
dieselnut123 1 post
I am replacing the batteries in my truck (they were very dead when I tried leaving for work this morning). I also need to replace the terminals as they are pretty beat up. I don't have a wire gauge tool but by my measurements based on copper diameter tell me the positive crossover between the batteries as well as both negative cables are 3/0 (000) and the positive between the starter and driver side battery is 5/0 (00000). Can anyone confirm this? That starter cable is certainly large! I'm having a bit of a time even finding a terminal that size. I'm all ears if you've got suggestions. Thank you very much!
