Need Help Asap With Airdog
- Replies 89
- Views 20.8k
Ltk 13 posts
guesswho512 11 posts
diesel4life 9 posts
Yankneck696 8 posts
Believe it or not, the vp44 will make the truck run whether or not there is fuel pressure. It will suck the fuel like a vacuum, but this causes wear and damage. I suspect you have the in-between d
hey guys, i have an airdog 2 150 gph pump on my truck.
yesterday when driving my fuel pressure all of a sudden hit 0 and i continued to drive home because it wasnt acting funny. when i shut it off and turned key back to run position, the pump wont kick on. ive tried everything i can think of. i traced the ground and hot wires as good as i could without a test light. i made sure they had good clean connection. (dropped my test light on the walk from the building to the truck and broke it of course)
i couldnt test the relays, and dont even know where to begin and what to begin looking at because i did not hook this pump up. i dont know which relays or fuses or whatever the pump connects through, anything like that.
i am showing error codes P PCU, P0500, P0462, and P1693. all unrelated id assume.
can someone please explain to me how to figure out if that pump is burnt out or not. if it is i need it replaced like 3 hours ago. college is starting back, i cant get to work, im at a loss for ideas. anyone that can take the time to help me, i can pay you some money for the time
thanks guys,
Logan
