- Replies 23
- Views 3.9k
Wild and Free 10 posts
JAG1 4 posts
diesel4life 3 posts
Mopar1973Man 2 posts
Did an end to end full service a couple weeks ago on my 2010 Dodge Hemi 1500 and today I started it and noticed a puff of blue smoke at initial start.
The cab fan is sqealling like a bearing or brush is going bad, been progressively getting worse the last 6 months.
Since I serviced the tranny I notice it is slow to built tranny pressure at initial startup and shift into gear. Wondering if the aftermarket filter came off or loose It has 2 internal filters the standard sump and a spin on TC filter on the cooler line with a cheesy plastic filter stud. If I put it in neutral for a few seconds before going into gear it is ok but let it idle for about 10 seconds in park and go into reverse it has a couple second lag before it is in gear, same with drive. This just started after the service.
Then it sounds like i have an idler or one of the belt driven items making noise under the hood now too, all this developed within 2 weeks except for the fan. If things keep going this way this Hemi is going down the road real quick.
The blue puff at start up and the laggy tranny both concern me.
And of course no more warranty, only came with 3 year 36K.
Edited by Wild and Free
