Pilothouse/RAM3500 build
Edited by PilotHouse2500
  • Replies 601
  • Views 245k
MNTom's buddy showed up Saturday to pull parts from the '94 cab, I hope to get the other cabs to my house early Nov to start the cab production process.  Going WAY slower than I wanted to.
Well, at least David showed up! I forgot all about this thread. I'm glad you are progressing even if it is slowly.....
  • 4 weeks later...
got a few doors it seems I'll be using to make the rear cab door and windows!
I got one cab moved this weekend to my garage and will move the second this Friday.  So hopefully you'll see some more movement here finally!
  • 5 weeks later...
Cabs all cleaned out of parts, bare cabs now.  Most of the dents pounded out as good as they need to be prior to cutting and welding (which will cause their own issues).  I hope to start cutting in Jan.
well as the site has been saved, I'll keep my progress here up to date.
Below is the prep work done to start cutting the front cab up.  Fingers crossed!
here is a pic of something similar that has been done cabwise at least.  This boy has had a TON of other mods done from the original 48-50 model area hood and fender sections and having the cab chopped, but you can see where I'm heading more clearly on the cab section.
  • 3 weeks later...
spent the day cutting cabs up...now the parts go will go off for blasting prior to puzzling back together.  I toyed with the idea of making the rear doors 24" but it seems to stretch the cab too much so I think I'm gonna go with the original 18" size I had planned.  I split the cab down the back middle to widen the back to keep the sides of the back angling out as it goes back. The rear of the front cab half I cut the center out to do that.  Helping me today (and thru the cab build) is Bob my local paint guy, I'm paying him to help and teach me what to do, especially the cab roof rebuild as it is compound curves all over...I'll get to learn how to English wheel!
pictures of the cutting:
a picture of all the parts:
and a picture of the final cab size:
  • 3 weeks later...
Cab parts off to blasting yesterday...week or so to get them back and the puzzle begins.
Do you have the cab welded back together? Are you priming it once it gets back from being sand blasted? Not sure how humid it is up there, but here even during the winter in an enclosed shop if its not heated 24/7 bare metal will develop some surface rust if left exposed long enough.
once back from blasting it will start to go back together.  My local guy who does paint for me (NOT a paint guy myself) who is mentoring me on this project will get it cleaned back up and reprimed after it's back into one piece.  I'm hoping to get primer on it within one month of getting put back together.   And you have a very valid point, fresh blasted steel LIKES to rust.
meanwhile...something came yesterday for TODD (trucks name if you didn't know)...what do you guys think?
I'm gonna run air ride any way so I'll have a compressor for that, so maybe just oversize that a little or run a second one for the (normal) semi horns and this monstrosity.  I've lined up an old scuba tank for the train horn (good to 3000psi) and will work the kinks out on that set up next month with my buddy who is doing the same thing for his vintage firetruck.
cab parts back from blasting...a few spots I knew would be Swiss cheese, but some surprises.....
  • 4 weeks later...
yesterday's progress:
I like following this project.  Keep posting updates and pictures.
  • 4 weeks later...
spent some time yesterday building and welding in the top of the door jambs.
Nice, I recommend watching the episode of "FULL CUSTOM GARAGE" where he sectioned a vw bus, lots of good tricks shown
I'm super curious on how that going to work out with expanding the body and get it all welded back together and paint ready.
lots of English wheel work and LOTS of tack welding the pieces back together so there is little heat deflection at the joint.
