Pilothouse/RAM3500 build
Edited by PilotHouse2500
  • Replies 600
  • Views 233k
thanks.  I've got a few plans that it will be near impossible to steal unless you tow it.
PH2500 What a great build!
On ‎1‎/‎31‎/‎2018 at 4:24 AM, PilotHouse2500 said:
got the '94 pulled into the shop last night to thaw out...any parts you want off the body, speak up before they get scrapped!
boy, sure do like that front bumper :whistle:
sitting on the racking outside the shop waiting for you to pick it up!
  • 3 weeks later...
contemplating something similar but using my 3500 4 x4 V8 and binning all the fuel injection/ecu's, there's a very old dodge dually on ebay.uk that has no rust but it's 9k. I wouldn't double door though as no skill for that, about 10 years ago I imported a job rated, 56 I think it was, but got rid as some **** had fitted a chevy 302, probably should have kept it LOL
Good news is I've decided on a few things and I'm in the midst of a huge kitchen project that will actually let me get the trans bought.  I'll be moving the engine back 2-3" to use the stock CAC and buying an aftermarket RAD with electric fans to get things stuffed up front where they belong.  I also plan on taking the summer off woodworking so I can get some headway going on this project.  SO hopefully come mid May this thread will get more updates than it has in the last year.
Money comes in Saturday!  Salivating over the trans swap coming!  Any final thoughts (prayers accepted) on this?  Still kinda debating the G56 vs the NV4500 swap, but cost might drive me to the NV4500 regardless.
G56 off the table, NV4500 is the choice.  Now to get the "extreme" version or the standard?
  • 3 weeks later...
On Friday I ordered the NV4500 tans!  2-3 weeks for delivery....sadly they don't take an auto as a core anymore.  So now I have an auto with under 10k miles on a rebuild, but no documentation since my buddies wife tossed all the paperwork on the rebuild years ago...sigh..
parts are coming in!
And finally....
Torque converter and Ring gear off.
transfer case pulled from the auto
Watched a video yesterday of a guy doing a manual swap up in Canada.  He mentions something about not using the vacuum lines (on the TC) and going to manual switch.  Anyone here done that?
meanwhile got the TC shifter taken apart and cleaned up...it was frozen solid.  Nothing a 20 ton H press can't fix.  And got to use my "new" media blast cabinet I bought from my car club friend.
progress from the weekend.  Transfer case cleaned of grime and crud.  Trans mounted to bellhousing.  Not in current pictures: steel parts painted with POR15 (did that after the pics).
TC and trans mated and sealed, tonight degrease and paint?
done for now, primed and painted...what's next on the list?
Looks good.
If you ever need a really nice finish that holds up to even light scratches give this stuff a try, its pretty. Awesome stuff. We restore all sorts of small and large mechanisms and the sort, good for hardware finish as well.
We call it Galvabrite.
Really makes a nice finish.
https://www.apidistribution.com/crown-galva-bright-premium-16-oz-aerosol
You can shop around and find it at different places, I get from McMaster Carr.
Edited by Timd32
  • 4 weeks later...
TC shifter cleaned, painted and reinstalled.  The grommets were a PITA!
You must have a glass bead blast cabinet. That linkage looks awesome.
One thing I really miss and need to get a decent compressor set up for.
I'm still on the fence about painting my 47RE, but the more I see your posts I don't see how I can't... looks great.
