Pilothouse/RAM3500 build
Edited by PilotHouse2500
  • Replies 597
  • Views 225.4k
Ummm... I'm going to need lot more funding to make that happen...
I got a dollar!  :lol2:
He has to go by way of my place in NW Oregon first to change injectors and  one power steering pump on both my 2nd gens. :stirthepot:
  • 2 months later...
well fall is upon me....I will start up serious work again on the truck here this next week!
Meanwhile a cool wooden model made of my resto by HomeSkoold Customs!
So I'm spending a small fortune at Summit right now to get the parts I need for the cooling system rebuild, and started to poke at the brake system as well.  On the MC is there any preference performance/use/life wise on an alumium body vs. cast iron?
Brakes go for aluminum. Cast Iron will rust and have issues as the brake fluid is hygroscopic (absorbs moisture). Aluminum will not react to moisture whereas cast iron will.
Agreed.  Assuming the quality of the 2 is the same.
Summit....you get what you get.,..Dorman parts
Cooling system plumbing worked out.
that boost elbow gonna rub on your coolant line?  hard to see in the image
No...inches away
22 hours ago, Me78569 said:
sweet.  looks great then
Well technically 1 inch, but plenty of space.  I worry more about the top rad hose and the oil fill tube bracket...might have to do something there.
Looks like the original oil filter is still installed.  Now I see how you are saving money!
Nice job with your plumbing skills.
- John
Edited by Tractorman
Rad core bracing fab'd and installed.
That's funny cool Pilothouse, I like that. Keep up the good work I know you'll sell it to me because I'm going to make an offer you can't refuse. lol!
