Looking for Staff Members
Edited by PilotHouse2500
  • Replies 559
  • Views 202.4k
Not much to report on teh truck work.  I've filled in some holes ands detented areas to smooth the jamb areas is about it.   My painter will be ready in one year, so I HAVE to get things moving into high gear to hit those dates.  Meanwhile, I'm spending a majority of my time building the new shed.
Nice work. Nothing better than springtime and putting up a new building for yourself. It makes for a good time :thumb1:
11 hours ago, Mopar1973Man said:
Man I wish I could build something that big for a shop and have a 2 post inside with wood stove and lots of room.
You actually need to do that Mike. Bringing a shop and equipment to a professional level makes everything go so much better. In the long run you will be financially ahead. I would amortize it over 15 years because what you can write off each year, the building costs and equipment depreciation will offset the payments that way. In the end you have a much higher social security income too. That comes each month without working and is the best investment you can make.
  • 4 weeks later...
Steel all around.  Roof got weather tight this last Monday.  Now I get to finish the steel siding (yes I paid for the roof steel to get put on).
  • 4 weeks later...
While waiting to get more work done on the new shed, I have time to work on some stuff on TODD.  So, the rears were removed, cleaned up and I POR15'd the exposed work where I knew it'd be hard to get to for coverage from the door access panel area.
  • 4 weeks later...
parts came back from the plater!
Rear door inner handle
375725751_701826881986255_1546602701404098294_n.jpg.e0b30b61814759c4916f8d616961ed5e.jpg
Vents
375466866_701826945319582_8389365048295688598_n.jpg.b69714a8f1b062c1de68bf96ee8dfd59.jpg
Valve cover
375465497_701826978652912_8509472170709871830_n.jpg.afc37ae7422591e0795b39ce44c069ba.jpg
Well, short of a few things to tidy up, "Pa's Shed" is complete for the year and I plan next weekend geting back to the truck.  Got lots to do, so hopefully I can keep motivated and start to wrap up all the loose ends there!
  • 4 weeks later...
  • 3 weeks later...
few days of work shown here:
rear door skins made
image.jpeg.dffcca9a7b7829394539783980eeb82c.jpeg.b4c0da45cf1ab571ed1d7cb2e37f1b4e.jpeg
prepped rear doors for skin addition
image.jpeg.aef77e75451bc3e41ac7846b29cea59d.jpeg.ea14ab9042dd1ba93a31747a85d1956d.jpeg
added power blocks for the rear window  power
image.jpeg.5f2042283642c9f7e899dccd8f019ebe.jpeg.c6409da592a62c2f803251727653a546.jpeg
image.jpeg.e769a48ab546cd6d420decbcf6e6ef63.jpeg.511f0a655f9aa76acc14753fbb40ba2e.jpeg
rebuilt door side of the check arms replacing and re-enforcing the area
image.jpeg.bd3308eedfc8438b9afd77035f03b2d7.jpeg.cf5298ba6ff825c3987d8dcde657a31b.jpeg
image.jpeg.e5bd44e1230ef0ec1ec5ada8ace9232d.jpeg.a3f2d1beb4756debdb24a9c0d75d7704.jpeg
