Edited by PilotHouse2500
  • Replies 584
  • Views 215.4k
I’m recommending using the corner lights and duplicating that look with the three center lights. Worry about stake pocket later
I did this to see how it looks.  Use the corners to be the lights.
or this:  mod the lower corner to be 45° and mount a single light to be side AND rear.
I just scrolled this whole thread. Amazing work. Thank you for sharing your time!
What I was trying to suggest is using the corners as in the 1st photo and drilling holes in rear for center 3 lights which would likely eliminate center rear stake pocket. I believe that most stake beds don’t have a center pocket anyway. Just my $.02
Ya, I just spaced out "evenly" the pockets...there will never be a stake panel in there and it's more for looks than anything.  Center rear three will be on the "bumper", and I mocked up what I'm now going to do on the corners for marker lights.  TBD if I will do side marker/turn signals....
  • 3 weeks later...
  • 4 weeks later...
Hell yeah. Its time to see color put on the body... :thumb1:
I'm guessing it'll be in Jan when he can start.  He needs to get his building finsihed and inspected prior to starting to actually work in it.
  • 4 weeks later...
I went for it yesterday on the first running board top skin.   Those long beads are tough to try and keep straight.   Did I?  Mostly.....at least its gonna be Rino Lined and not gloss back!
I'm still waiting to see this truck run. Oh it's going to be pretty and a radical oldie.
....so am I...so am I....
Passenger side done.   As typical it went better and looks better.  I figured a way to jig the bead rolls so it went much better.
  • 3 weeks later...
My OCD decided I needed to redo the first running board to be "nicer"....so I did!
475119603_1042283691273904_5519799981832115010_n.jpg.70909e14ace25a970b2910b4b1ca4bc0.jpg
And I started to trim the grill bars so they fit right by the intercooler.
475502971_1042487511253522_1836548929387680849_n.jpg.d60cfa30db7c6245ae157aa63e3f0eef.jpg
