- Replies 15
- Views 3.5k
Matt0matic 5 posts
Mopar1973Man 4 posts
Dieselfuture 2 posts
mopartechnician 1 post
Trying to diagnose a my truck dying while driving down the freeway.
Truck is a 1999 Cummins 5 Speed in a 83 Ford.
VanAken Box
1/2 Napa fuel strainer before the Fuel pump
Walbro 255 Fuel Pump
20 Mic Water Separator w/drain Donaldson P558000
3 Mic Fuel Filter Donaldson P551313
1/2 fuel line from the sump to VP
The Fuel system is all brand new from tank to the filters to the 1/2 line to the VP as of 6 months ago.
Here is how yesterday went:
Brother gave me a bottle of Power Service Diesel Kleen and figured why not try it, I haven’t had a heavy trailer on in a while and have been using it on short trips. Filled up 38.8 gallons of fuel and poured in the dosage for 40 gallons.
Loaded up a trailer full of wooden spools and moved them to another job site 30 miles away I get literally one mile from my destination and the truck dies after I let out of the throttle coming off the freeway. Had 20psi fuel pressure when it died; after that it would just turn over and not fire when ignition was engaged.
I get a coworker to pull me off the freeway and I put the truck in gear to slow down to keep from hitting him, at this point the truck fires up from the motor turning over while in gear and remains running. I end up being able to drop the load of and return back to the shop 30 miles away without a hiccup, same 20psi fuel pressure.
End up running some errands and total another 40miles on the truck until it is time to go home at which the truck dies again as I let out of the throttle on an off ramp en route to the yard. Had the boss pull my truck the remaining one mile to the yard- and again the truck wouldn't fire with the ignition but it would fire from being pulled and slipping it into gear. Still have 20psi showing on the gauge.
Today after work I get to take a look at the truck- flip the key to run, where normally it jumps right up to 20psi BUT this time it slowly climes to 20psi. I check the voltage at the pump and it is only pulling 8.5v, disconnect the pump and I have 12.5 at the wire. I replace the pump with a new on and now it pulls 9.8v- but it still is slow on reaching 20psi. After bleeding the air out of the system the truck fires up and runs for about 3 mins surging the whole time and eventually dies on its own accord.
My next step is to replace the fuel filters and if that doesn’t clear it up going to take the wiring harness of the VP and just give it power and ground to rule out faulty IP.
Any suggestions or advice?
