Ca smog and lift (tranfer) pump codes
Hey all, I have to smog my truck for the first time. I have a mechanical fuel pump as the stock pump died. I usually have the smarty take care of the error code but sine I have the stock tune loaded, the transfer pump code pops up and triggers the engine light. Is this gonna be an issue with smog? Im thinking of trying to put a dummy load on the pump plug of maybe 5ohms? Does this seem plausable or is there an easier way around this?
Thanks
  • Replies 15
  • Views 2.9k
I do not think you can have the truck smogged with a code, and you need to clear the code and get a certain number of miles on it to be acceptable one time it was about 50 miles not sure what it is now. maybe a light bulb in place of the pump may be acceptable.
I have heard you need some miles put on too. That's why I have been driving it in stock form and trying to get everything straightened out before I take it in. But man is it gutless without the Smarty. I have heard of people getting hassled for not having the breather puke bottle too, hope that's not the case as mine is long gone. I'll report if the resistor works. Thanks!
Grab a standard 30A relay and wire pins 85 and 86 to the lift pump circuit and the code should be stopped then just clear the codes and drive for awhile. Remember all AirDog fuel systems are triggered by a 30A relay.
Michael, the relay worked perfect. No code. Thanks for the idea as I have a bunch of relays laying around. I should have thought of that. Just gotta put some miles on it and take it on in!
Your Smarty may not  be legal in CA. I brought my truck in for smog test in December of 2011 and every thing was good. Last December I was told that my EDGE E-Z was not legal and I'd fail the test. Lucky for me I've known the owner for 20 years and I send him a lot of business.He passed me anyway. I went to the CA. ARB web sight and the EDGE E-Z was only certified for 1998-1999. I could not find the Smarty listed there so it may not be certified either. here is the web address.   http://www.arb.ca.gov/msprog/aftermkt/devices/aftermktdevice.php
I see that the Smarty leaves no "foot print" so you may not have to worry about it but be sure no smoke comes out of the tail pipe. The test includes revving up the engine and watching the tail pipe for smoke, any smoke at any RPM is a failure.
Edited by IBMobile
I think for a diesel that this is a little ridiculous. Even when these things were brand new Ill bet they smoked at least a little bit when you revved them up quick.
Level 0 if I remember right will not smoke at all. Our sled puller running 150hp injectors, smarty, and adrenaline would barely haze on the no smoke tune
Restoring the factory tune should work, regarding the Smarty. That's what the previous owner did and it passed no problem. I cant get it to smoke at right now. I had a tech look at it and he didn't like the bhaf, but said if I showed him I had the stock airbox it would be alright.
All I can say is I am so glad to not live in a smog controlled area. Seems like such a hassle to just have the vehicle that you want and have it the way you want it.
They are complaining about an upgraded air filter? WOW...... Glad I live where I do. My truck would never make it out there.
Passed no problem. Technically can't have a modified intake without a CARB certification. They weren't too concerned about it, besides it takes 2 min to swap the air box. The guy never even did the snap test. Go figure...
My friend didn't say any thing about my bhaf or the home made cold air box but did do a snap test and said he did see a little smoke but hay what are friends for.
