- Replies 14
- Views 4.6k
rancherman 5 posts
flagmanruss 3 posts
dorkweed 1 post
mulcher812 1 post
My son has been out of the Marine Corps. now for 4 years... He was infantry.. His main job was manning the 50 cal. mounted on top of the Humvee on patrol. Did 2 tours in Iraq, and 1 in Afghanistan.
His passion for weapons, systems, and other warfare is strong.
He found an outfit a little ways from here that sells body armor, in Iowa. The plates he bought are shaped identical to the ceramic plates issued to him in the Corps... but are made out of steel instead. The ceramic plates were a full inch thick, and very heavy. These steel plates are 0.27 (with paint) He is thinking these steels are going to be slightly lighter in weight.
He has the harness to slip these plates into, there are 4 pieces to cover the vitals; chest, back, and under each armpit
The companies claim that these plates are 'bullet proof' is something one shouldn't take for granted.. and testing seemed prudent! After all, blind faith in a claim isn't very smart!
So, last night, we took one of the small plates (cheaper to replace) to sacrifice in a test firing.
We also grabbed a scrap of 3/8ths mild steel plate for comparison...
Test ammo; Russian 7.62X54, 220 grain. Soft tip, FPS: 2700 Figure this round was going to be somewhere between a .308 and .30-06
Range from rifle; about 100 feet
I put a coin ( quarter) and a 3/8ths bolt on the plate for size comparison... Amazing the 1/2 inch hole a .308 bullet made! 7,62mm and .308 is the same diameter
Conclusion: The test was successful. The armor plating resisted puncturing, it only showed a little 'center punch' type ding, and the chipped paint!
Granted, getting hit with a large rifle round such as this (you might not want to be alive afterward) is going to knock you end over end...
But for small cal (AK47, and pistol) I think these would be perfect
Edited by rancherman
