Who's Burning?
Just curious here...........
I've only lit the stove 3 times so far......................and no more than just 1 reload after each one.  Just to take the damp/chill out of the house.
It's been a relatively mild fall so far...............only 2 mild frosts.  A lot of rain and damp though!!!!
  • Replies 60
  • Views 10k
Been burning off and on since October first. I've got 8.5 cords in the shed split and stack and dry. I'm ready. I've also got another 2-3 cords in rounds and logs yet to be processed. Mornings are cool to cold ranging from 35-45*F and day time highest been barely 70-75*F.
We cleaned our stove pipes and have had 2 fires. I come home from work wet and need dry heat to get warm and dry. Our lowest temps have been 43*, but we've had some highs only in the 50's. Gets down to high 50's in the house at that point. Only takes a couple hour fire to get us toast warm. We only use 3 or so cords here.
I'll probably start burning in late November. This week the highs of 75-85 and lows  59-62
Michael is still sleeping....he fought a "hot damn" chimmney fire last night from 10pm-3am this morning.  He'll fill in details later.  In the mean time we're pouring down rain here. Peace Moparmom
Well... (Yawn) I got a called out to chimney fire last night the owner managed to put the live active fire out. But the creosote smoldered for quite some time creating hot spots in the blocks and walls. Nothing actually burned on the outside of the chimney but got it dangerously hot so all we could do is ventilate the house and cool the walls down by air and monitor.
I highly suggest all wood burning people inspect your chimney. If you have a older block and liner chimney I would also suggest you consider getting a stainless steel liner installed.
And even if you are going to run a stainless liner, the chimney still should be swept prior to the liner install.
Does your dept. use any thermal imaging cameras to find hot spots?
Don't I wish... We where just talking about just having a laser thermometer would be awesome even for this purpose.
I just bought stuff to do my own chimney cleaning. My main stoves pipe had very little buildup. Wood we are burning just doesn't create much creosote. No gooy stuff. Just a little flakey. Doing it myself helps with knowing how often it should be done. We've paid to have it cleaned before. We have a metal roof, so I did it from inside. Have a slide section to remove pipe that's inside the house.
Edited by joecool911
If your wood is "truly seasoned", you'll get very little gooey creosote in your chimney.
Burning wet/green wood and letting it smolder causes the moisture and the smoke to settle inside your chimney...................creosote.
After almost 5 months of burning last year, I only got about 5 cups of flaky, dry creosote out of my chimney.  The stuff that looks like coffee grounds isn't near a dangerous as the gooey, tarry stuff.
ARTICLES - WOOD - CREOSOTE FROM WOOD BURNING - CAUSES AND SOLUTIONS
Burning wood, no matter how you do it, releases pollutants, mainly in the form of gases and particulate matter. There is no avoiding this but, how these things are dealt with in your wood burning appliance can vary greatly - not only in the type of stove you choose but in how you operate it. One of the main dangers of wood burning is the excessive build up of creosote in chimneys and stove pipes.
Creosote is a gummy, foul smelling, corrosive and extremely combustible substance that, if no precautions are taken, will coat the insides of everything it passes through. It is formed when volatile gases given off in the burning process combine and condense on their way out of the chimney.
The gases leave the burning wood with the smoke. If the smoke is cooled below 250 degrees F, the gases liquefy, combine, and solidify, forming creosote. Creosote takes several forms, all bad. As a liquid, it can run down the insides of pipes and chimneys, oozing out of any openings. It can form a hard layer coating the insides of pipes and chimney liners. It can form into a fluffy substance that plugs pipes and breaks off and falls down, filling low spots in piping. It is the cause of most chimney fires and the main reason chimneys and pipes have to be cleaned and inspected periodically.
Many of you are old enough to remember the rush of people buying wood stoves in the oil embargo days. As a result, the early 1970s saw an explosion of companies formed to meet that demand. If you remember that, you might also remember the rush of people abandoning wood heating and the demise of many of the companies manufacturing those stoves.
It wasn’t that these stoves were all bad or that people were all foolish. What happened was that, number one, the EPA imposed pollution standards on the manufacturers that they were either unable or unwilling to meet and, number two, the people who bought these stoves came face to face with the fact that operating wood stoves is a combination of science and art, a large part of which is dealing with creosote.
The revolution in stove design in the 70’s was the introduction of the “airtight” stove. No more getting up in the night to feed the stove; you just pack it full of wood and choke the air way down so as to produce a long, slow burn. Where formerly, you controlled the burn by limiting fuel to the stove, the new way limited air. The benefit of this was a long nights sleep. The price was a chimney full of creosote.
An air starved, slow burn, produces relatively cool stack temps ideal for creosote formation. People would get up in the morning to a warm house, not realizing they also had a system partially plugged with a highly flammable material since this had never been a problem before. Fireplaces and older stoves produced roaring fires that either burned the creosote out or kept stacks temps above 250 degrees so that the gases escaped without condensing.
Creosote such as this can usually be brushed out
The ensuing chimney fires and the mess and expense of having to clean out the chimneys periodically caused many folks to sell their stoves and go back to gas or oil. Many of these stoves are still around, however, and the people who own them have learned a thing or two about wood burning. One thing many of these people do is to start each day with a roaring fire. This not only gives rapid heating to a house cooled off during the night and gets your coffee pot perking, it also burns out creosote that may have formed during the night. The result is a series of mini chimney fires that, if done every day and carefully controlled, are small enough to present no hazard. This technique, of course, is only effective for creosote in the stovepipe near the stove. It does nothing to address any problems near the top of the chimney. Also, if the chimney already has an excessive buildup of creosote, the above could spark a MAJOR chimney fire. As with any user-operated appliance, there is no substitute for familiarity with your specific installation, stove and chimney.
To fire a stove properly, a stack thermometer is essential. The most common type is a magnetic clamp-on that is attached to the stove pipe above the stove. They are slower to react and not as accurate as probe types but they will tell you all you need to know to fire the stove. Just don’t pay any attention to the zones most of them have indicated on them. For example, mine labels temps above 380 as Overheated. If I followed that advice, I would be loaded with creosote.
Glazed Creosote is difficult to clean and extremely flammable once ignited
Creosote build up is pretty sneaky. You may not notice it at first but it tends to feed on itself. As it builds up, it restricts the flow in the chimney and/or stove pipes. This slows the smoke on its way out, allowing more time for it to cool and for the creosote to condense and deposit itself thus further restricting the flow. If youdont burn it out every morning, it quickly builds to a point where it is dangerous to do so. The only course left to you then is to take the pipes down and clean them and the chimney. Hopefully, when your stove was installed it was installed with short pipes and few bends. Taking creosote filled pipes down makes a real mess.
As for the chimney, you can buy chimney brushes with extending , flexible handles that allow you to brush the chimney from a clean out on the bottom. You can do a reasonable job that way but, its no substitute for a thorough cleaning and inspection which should be done annually.
Whether you climb up on the roof and do it yourself or hire a professional chimney sweep, is up to you. Either way, its best to do it in the spring. Creosote is corrosive and it pays to remove it as soon aspracticle . The moist summer weather can cause creosote smells in the house so, best to get it done as soon as the heating season is over. If you hire a sweep, he or she is apt to be more readily available in the spring than in the fall and might even offer a discount for off season employment.
Failure to follow these maintenance procedures could well result in a massive chimney fire. This is a truly frightening possibility. People who have experienced them say they are accompanied by a great roar and sparks and flames shooting out of the chimney. The best way I know of to fight them is to completely close off all air to the stove. For this to work you have to maintain your door gaskets, dampers etc. Once you have done that, call 911 and get out of the house!
There are only two ways to prevent creosote formation in chimneys. You can either keep the chimney above 250 degree F all the way out the top or, you can burn up the gases that form the creosote in the stove before they reach the chimney. Modern stoves do the latter and capture the heat produced by essentially burning the smoke.. This is true of stoves with catalytic converters and non-cat stoves that burn gases by recirculating them. Either way, less smoke means less creosote. Burn the smoke and you burn the gases. No gases, no creosote. As simple as that.
The wood you burn has a lot to do with creosote. All firewood contains water in some degree. How much it contains is important. Wood dried outside, stacked where the wind will blow through it will end up in my part of the world with about 20-25% moisture content.That’s about the best I can hope for.
All the water contained in the wood is turned to saturated steam as the wood burns. It enters the stack as steam and water droplets at a temp. of around 212 degree F. This is considerably cooler than the condensation point of the creosote gasses, 250 degrees. Thus, the presence of the steam cools the chimney, the gases condense and creosote is formed. This is true whether you burn hard or soft wood. The moisture content is all that matters. You can’t eliminate it but, burning seasoned wood will keep it to a minimum
Finally, the size and placement of the chimney, the chimney liner, the size of the flue, the length of the stove pipe and the size of the stove all factor into the creosote equation. These are matters best discussed with your stove dealer and building inspector if you plan on including wood heat in your new home or adding it to an older dwelling.
In summary, newer stoves and properly lined and insulated chimneys have done a lot to reduce the chances of excess creosote buildup, but there is no substitute for experience and education concerning this potentially dangerous substance.
Dave Johnson
Problem up here is the outside temperatures and how much exposed chimney you have. Like when I had my chimney liner install the pip stuck out another 12-16 inches from the original chimney. This now combined with the near minus temperatures doesn't matter how hot you burn that pipe is still cool enough to condense creosote. So you have to limit the amount of expose pipe as possible. I trimmed mine off right next to the existing chimney. Now this still doesn't fix it all. The existing chimney is all stone and block. As the cold winter come on the first 2-3 foot will plug up but looking down the chimney the rest is clean. I typically run 1,400 to 1,600*F pyrometer temp on initial startup and then cut back to 800-900*F as a burn temp.
I'm assuming that your running a stainless liner in your chimney here.
Is your liner "insulated"???  Either with a wrap or other stuff poured down your chimney???  If not, it'll help.
I have just over 7ft. of "class A" chimney pipe above my roof line.  There's just only over 3 feet of chimney pipe thru my attic space as my roof is only a 4/12 pitch;  and the only spot I could put the stove necessitated the chimney being where it's located now.  The manufacturer of my stove says 15ft minimum of chimney height measure from the top of the stove.  I'm a 16' now.  The only part that gets "nasty" is the cap;  and it doesn't never get near to plugging up at all.  It also gets pretty darn COLD here also!!!! :smart:
Here's a picture of my chimney and a load of white mulberry I hand split this AM!!!
Twasn't arguing Mike.................I was just asking!!! :2cents:  :cool:
No problem... It just my house was built back in 1960's and the existing chimney is old cinder block and clay brick liner. Now stuffed a 6" stainless chimney insert into it has helped but doesn't fix the cold weather months problem it seem like every year around Dec/Jan it start to plug up even though my chimney pyrometer hits 1,600*F and then cooks at about 800-1000*F all day long. But the top of the chimney you can put you hand over the top and its not that warm at all. So it cools quite a bit between the stove and the roof. Which is about 20 some odd feet.
Doesn't look like this, does it???
Ummm... Err... Ummm... :ashamed:
I've had one last year where I could tell the chimney was starting to choke right in December but it just snowed so I hung in tight. Next morning I built a fire and wasn't long and smoke was rolling back in the house. So now I'm shutting down the stove and waiting for midday and hoping to climb a slick roof. :ahhh:  What I found was the creosote piled up in the exposed chimney area (the coldest part) and created a flap from the side wall that got warm with the starting fire and fall over shut and plugged the chimney completely. Mine wasn't as bad as the video. My build up depth is about 2-3 foot of the top and the rest is smooth and clean below. :shrug:  I don't have any stains. But on occasion I get chunks of creosote that dropped on the roof. Thankfully I've got a steel roof.
Funny thing is I re-stoked the fire and now its so flippin' hot in here its like summer time all over again. Ugh. Should of like the darn thing go out. :doh:
...I'll trade you. Wood is without a doubt one of the best feelings I ever experienced. Nothing more fulfilling than the thought knowing you can cook yourself right out of your shelter in the dead of winter!
As they say wood warms you more than once... Fall and buck up the tree, load it in the truck, unload the truck, split the wood, stack the wood, etc. I was just thinking that I'm burning roughly 1/4 cord a week or 1 cord a month. So at that rate I need roughly 7 cords. I've got 8 cords as of now. I've still got another 4 cords unsplit. So I'm already bring on the winter. I know I got to crawl up and brush the chimney one last time... Maybe this week.
It would be cool if they had a piece of pipe inside the existing pipe that slides easily up and down to clean the chimney. It would be on a chain and pulley so you just go outside and reach up near the gutter/ eave and pull till it's cleaned again.
I believe that I'm "officially" 2 years ahead in my CSS wood supply!!!
I have this winter and next winters wood CSS (cut, split and stacked).  I'll get some pix for y'all shortly.
