- Replies 14
- Views 2.5k
Mopar1973Man 4 posts
CUMMINSDIESELPWR 4 posts
Ilikeoldfords 1 post
rlane547 1 post
Well ever since I've starting to work with Lindy I've really taken interest in making my truck near perfect again. I'm actually chasing down all the little weeping leaks. Like I've known about a fuel leak for quite awhile in the back either #6 injector line or the return at the back of the head. So since I've been keeping the rig washed down it really showing up now. So now I pulled the valve cover snugged the return banjo. This really made the job easy to reach the banjo bolt. As a matter of fact the IAT sensor is a breeze to get at without the hoist ring and the valve cover. Then backed off and reseated the injector line. So later on I got to degrease the back of the engine again and check again. It leaves a light fuel residue on the block and bottom of the bellhousing. But never drips on the floor of the shop. I'm also watch my pan gasket start to weep a bit. While the valve cover was off I might as well run the valve lash again. Not really bad but some were just a bit loose for my liking. Intake (0.008") and Exhaust (0.018"). I like snug!
Needless to say in the wet highway 4th gear spins the tires now...
