- Replies 12
- Views 10.4k
mopartechnician 3 posts
CUMMINSDIESELPWR 2 posts
Rayce 2 posts
98whitelightnin 1 post
Looking at this problem appears to be a real pain to access in order to replace a simple gasket.I grew up doing my own repairs on gas engines, & don't know enough about diesels. I have learned from running out of fuel,how to bleed the system quickly. My main concern is do I have to remove the injection pump in order to do this, or is it possible to replace the gasket with the pump in place? Removing the pump scares me,because it went bad & was replaced 6 yrs.ago costing me $3,600 bucks! The shop replaced it but had to take it to a dodge dealer to time & calibrate it with the ecm,& that Cummins couldn't even do it cause Chrysler had changed the codes & won't give them out. Work has been really slow,& I can't do any without my truck!...Please help? Thanx,Rayce
