I have a 1999 24v cummins. I'm probably the 4th owner, possibly 5th. A previous owner had installed exhaust mods, fass DDRP v02, Edge Juice with attitude. I'm not sure of any other modifications. The DDRP went out on me the other day on my way home. I limped truck home. After sitting over night and trying to start the next day, truck was showing 0 fuel psi anywhere and i couldnt hear the lift pump at all. I was limited by funds, but replaced the lift pump with a napa one (airtex i think is the brand - not ideal, i know)
Truck then was showing 21psi at the top of the filter cap, but 0 psi leaving the filter cap. My edge, which i believe checks psi at the VP44 showed 0 psi until i would kick the starter once. Then i twould jump up to 14-20psi right away. I have since replaced the battery cables as there was some corrosion and i noticed some cutting power to the edge occasionally.
I had the codes read, but unfortunately didnt get them written down. Mechanic said everything checks out fine, yet i'm still getting 0 psi when i'm on the highway under ANY sort of pedal. onlytime i show psi over 0 is if the truck is at an idle, then it will slowly climb back up to about 10psi (per edge)
I know that running under spec for psi is a sure killer of your vp44. I need some advice as to what could be going wrong here?
I've also changed the fuel filter.
Truck has 210,000 miles. Its unknown to me if the vp44 has ever been replaced or not.
Thanks,
