- Replies 23
- Views 4.9k
angus 5 posts
MnTom 4 posts
mopartechnician 4 posts
dorkweed 3 posts
I have heard that idleing you truck for extended periods is bad?? Well, I have a unique problem in that I work only about a half mile from where I live.. Morning temps are droping into the teens, and soon single digits.
I normally go out and strart the truck and let it run for about 15 mins, drive to work, and then let it run at least another 10 before I shut it off and go in... The high idle stays engaged most of the time.. about 1050-1100 rpm
Which is worse,, start it up cold, and shut it down cold? or let it warm up as much as possible?
