Lock up issues are back, fml
- Replies 11
- Views 2.9k
pepsi71ocean 5 posts
MnTom 2 posts
Mopar1973Man 1 post
Dieselfuture 1 post
So guys, I developed lock up issues Friday morning. My truck was going subtle in and out. Ironically at the exact same time my trans developed shifting issues.
Currently it is holding 1st gear to 2,500 rpm, and shifting between 45-55, and I also have the unlock and lock up problems as well.
I traced an issues with a loose positive battery terminal and the grid heaters.
Today I tested my vac, and I had .027-.033 at the batteries. And .04-.065 with the grids during away.
After fixing the terminal using threaded rod and some nuts, the grid heater drop is now 12.15v instead of 10.15v.
However, after the repair my alternator now is pushing .09 and the batteries are a little higher at .035-.04.
Now, I did ohm test the main cable between the two batteries and I got .03-.06 this was with the one side unhooked.
I'm so annoyed I don't feel like this alternator is fried, but currently I know it must be at the center of this.
It doesn't help that I also flashed the smarty again, and coincidentally this happened.
I'm going to try and get to Napa and see if they have another terminal bolt, I suspect that rod may not be helping it.
