Need some help for a buddy
- Replies 25
- Views 5.5k
AH64ID 6 posts
Mopar1973Man 5 posts
Wild and Free 5 posts
Ilikeoldfords 4 posts
So my friend has an issue.
He has a 2006 ram 3500 cummins with a 6 speed transmission. While driving down the highway last week all he started getting a really bad miss, then a bunch of loud clanging from the engine.
He got the truck into a local shop up in Wasilla that night. They pulled the valve cover off and found a valve spring missing. It's just gone. The valve dropped into the cylinder and got gobbled up by the mighty cummins.
So at this point, it would appear he needs a rebuild at the very least. Shop said the head is past rebuild able. The piston is toast as well as the turbo. Very bad deal all around.
If he were to find another motor, what should he look for? Some shops have told him he has to find a motor specifically for a truck with a manual transmission. Is this true?
Thanks for any info!!! I have some pictures I will post up of the damage a little later.
