- Replies 116
- Views 27k
Greenlee 55 posts
Mopar1973Man 29 posts
flagmanruss 6 posts
TFaoro 6 posts
I don't think advancing timing internally on the VP has anything to do with idle RPM. All that does is inject fuel sooner, and probably only beneficial for high RPM race application. As far as I know
This is exactly true... Special X pumps and Hot Rod pumps are now a thing of the past. The other problem like I've learned in tuning now is everyone forgets about their fuel cetane rating
Yes you could use the Timign reduction settings to pull timing until the turbo is lit.
Blue Chip Special X VP44 advanced timing
I am not sure what to do. Several months ago I bought a set of Dynomite Diesel 75 hp injectors through Parleys Diesel. Not supposed to smoke on a stock Cummins but when the injectors were installed, the black smoke was worse that any rolling coal on Youtube. I called Parleys Diesel explaining the circumstances and results of the injector install. Parleys had me call Dynomite Diesel. Both vendors were doing all they could to solve the problem. I explained prior that I was using a Blue Chip Special X VP44 with advanced timing built in. Brian at Dynomite Diesel runs the Warranty and Testing Department, excellent individual to deal with. Told me to send the injectors back to make certain there were no issues on their end. Brian retuned the injectors but he turned them down a notch. They are balanced and in harmony to work properly. I am hesitant to put them back in my truck, well I’m not doing the work, I have an individual doing the install for me. The last thing Brian said to me was if this doesn’t work then I have VP44 issues with the pump I am using. I paid $2,150.00 for the pump and over the last 2 years I have put 10,000 miles on my truck and VP44. Is there anything else I can do to check my system or is there anything I can add to the truck, a fuel management system or tuner that would improve what I have going on. My thoughts are if I want to use these injectors I will have to get a different VP44 or sell the injectors before I use them again and leave the stock injectors in place. I don’t know how far advanced the timing is but I get little puffs of black smoke out the back now when driving. No luck talking to Chip, the answer I got for using 75hp injectors was “there you go, a set of RV 45hp injectors would be much better”. However, on Chip’s web site they tell you 100hp injectors are fine to use but they will cause a lope in the idle. Any ideas? Could the fuel return at the back of the head cause these issues?
