1977 Ford F-250 Blue Top
I'll be getting back to this project here in the near future being the snow will start melting off.
Low Boost After Boost Elbow Install
Difference... Smarty just take the stock ECM data and backs it all up to the Smarty Module for return to stock. All the factory limits still exist so the fuel table only goes to about 22 to 25 PSI. All your doing with a smarty making the throttle a light switch it will be 100% CANBus fuel by 30% APPS signal. More or less follows the stock tune fuel ramp just more fuel quicker. Timing follows the stock layout of the most part just adding timing on top. Kind of why I dropped the Edge Comp after going to +75 HP injectors because the timing was way off and created a smokey tune that was super hard to clean up. Not to mention no longer efficient tune for such injectors being the timing is way off and the fuel map is too heavy down low to give that torque response everyone loves. It the same note also brought down the EPA on us all. Now Quadzilla set up right doesn't pollute much at all and like I've bested my own highmark of 27.2 MPG (Edge Comp with +50 Injectors) to 28.04 MPG (Quadzilla +150 HP injectors) I'm living proof that you can have your cake and eat it too. Quadzilla you now injecting full fuel maps and timing maps and not using any stock information unless below 1,200 RPM then the ECM now takes back over and Quadzilla only monitors engine data. If you want to do timing like a Smarty just set all the TIMING PARAMETERS to 0 then go to MAX TIMING and set the amount of PLUS DEGREES you want on top of stock timing map. Stock map is OK to use with stock or RV275 Injectors after that you should seriously consider custom timing. As for the fuel map you taking the stock fuel number and adding a percentage to the fuel number. Example engine load is 25% and the boost is 2 PSI for my so my programmed fuel for 2 PSI is 88% so the math looks like... Showing de-fueling 25% fuel desired x 88% fuel map at 2 PSI = Actual fuel commanded is 22% Showing increased fueling 75% fuel desired x 120% fuel map at 20 PSI = Actual fuel commanded is 84% Just to show WOT at 100% tuned... 100% WOT x 100% fuel map at 30 PSI 100% fuel map = Actual fuel commanded is 100% This is also why I'm one of the few that creates a stock fuel range in the middle of the map so you can have a more or less a streetable daily driver with little smoke and never cruising in a 101% or greater fuel map (Not Good). Then gang the wire tap and the CANBus fueling together at the same point. Right at the end of the 100% stock what ever PSI it start to rise that is the PSI you set to start the wire tap. Be sure ot set the max PSI for the wire tap in a reach able PSI so you don't short change the tune. More or less when I stand on it both the CANBus and Wire Tap hit together and the power is much more pulling you back in the seat in my case more times out of ten the tires break free and the blue smoke starts.
1998.5 47re auto hard OD shift
So in a nutshell you need to work on the timing more so. That is what will make or break a tune. Proper advancement at the right time and proper retard at the correct time too. When the timing is correct the Engine Load, EGT's, engine coolant, and the engine oil temp will be the lowest. Fuel map is not as important, being like my current tune at 65 MPH I float about 1 to 2 PSI back on my stock HX35W turbo, and that's about 84% to 92% fuel. Then I've got stock 100% all the way to 15 PSI. Again not as important as timing which will make or break a tune. Clues to give if the rattle of the engine goes away you most likely too retarded in timing advance one degree at a time till the light rattle is heard for the span. If a heavy rattle or tinny rattle you are most likely too advanced. Be aware that over advancement creates what's called "Negative Torque" in which the advanced timing started burning the fuel before the piston makes it to TDC so now the piston is being slowed by negative torque and losing power till it breaks over the TDC mark then the power comes out. So this is why I watch engine oil temp because advanced timing has more flame front in contact with the cylinder walls and engine oil will rise being the coolant around cylinders and the oil cooler rises. Again proper timing will have the lowest temps for EGT's and coolant, and the lowest engine load. If your IAT is below +80*F you might want to cover over the intercooler build the heat up it does help with efficiency and does not require more advanced timing to heat than cold air, so you don't have to constant re-tweak the timing for cold or warm air. Another clue, my MPG mode in the High idle kits was to hold the IAT at 143*F so it never dropped below +80*F so when it does drop below the ECM normally kicks in another +4* of advancement and retards again above 80*F. Warmer intake (80 to 140*F) temps actually do produce better efficiency on the tunes, colder than 80*F does hurt the efficiency.
Both Trucks showing up with slow to non working wipers...
Motor park reed problem, just need the wiper motor. Most likely the multi-function switch is wore out. Central timer is only used for the delay function as far as I know but never heard of a Central Timer failure for wiper delay. Being multi-function switch gets used and could have wear. I can also see if a bad wiper motor drawing too many amps cooking the central timer like the whole PCM voltage regulator issue. Still in all the years of working on these trucks I've never seen a bad central timer yet.
Missing People in Idaho
I get it since I'm at the end of my family line. Both my parents are gone. I've got no children and don't plan on trying now at 51 years old. Never been married. I've got no brothers or sisters. No other relatives left that I know of. I can really come to grips with what you're saying. Being I'm already out here in Idaho and no family left I still have days where I want to just vanish from people, phones, internet, etc. I more or less have my adopted families now. Like my neighbors keep an eye on us and we do the same for them. I've got some friends down the road that call to pester at least daily some times. I'm not alone but after realizing your family is gone and so is the responsibility, then you find out you have a bit of freedom. you'll come back out of your shell again. It's taken me a while to figure out who I am once again after taking care of both my parents since 2004 which is 16 years of taking care of my family. My Dad died of pancreatic cancer in 2004, then I moved back home to help my mother till 2020 when she passed away. Then get hit with COVID and locked down. So this coming summer is my time to spread my wings and find out what I want to do now. If you asked me if I would do it all over again. Sure I would I would do it all over again... That's what families do, they hold tight to the end...
Lets say I'm part of Idaho County Search and Rescue and I've not had a SARs call in quite a while. I typically work the southern end of Idaho County which happens to be the largest county in the state. As for missing people I'm not being called out for much. I've even got my monthly test pages on text message, phone call and email. So I know I'm part of the system yet.
Midna's build
If its OK, I would consider powder coat more so because of heat. Powder coat would hold up much better vs rattle can paint. Just a thought... Gotta admit its a pretty spiny thingy...
Government double standards
Then your same federal government telling us that our vehicles are polluting and need heavier smog control. These USFS control burns or out of control forest fires pollutes more in ONE MINUTE than our trucks will in a entire lifetime. Why is the federal government allowed to turn the other way and say oh, "It is a a natural fire with natural ignition oh its not polluting." I look at the amount of forest around me that is completely burned up and gone. The amount of ground that nothing was replanted which is quite a bit. Then living through the fire and seeing how thick and choking the fire can get. We got the same thing we are not allowed to open burn after May 01 of this year but thats about the time everything dries out after the rainy season for us. Maybe thats why I've still got a mountain of debris in my lower yard.
This is why I do not suggest any sealants like silicone because most people don't know how to use it properly. When it over applied then it breaks off and ends up in the oil pickup screen yes I've seen a few plugged with silicone trash. 99% of our engine was put together with sealants. The only place is the gear case that is silicone. Even that is grey RTV.
Surging while driving
My last timbo APPS lasted quite awhile not sure how many miles I would say over 250k being I got it just before @MoparMom went down with kidney failure. So in my case I did the same thing used cruise a lot but then once in the city lot of light to light driving though.
Nope. Done this quite a few times.
You don't want to see the gasket I made out of Napa cardboard label. Made in roughly 10 minutes and cost nothing. No sealant used. No leaks.
Dreaded P0216 code, help/advice
Buy a Flow meter then you cantest it yourself. CGOLDENWALL 1 inch Turbine Flow Meter Digital Fuel flowmeter for Water, Diesel, Kerosene, 2.65-23GPM/10-90LPM, 1" NPT Thread (1" Flow Meter) https://www.amazon.com/dp/B09G9878DK/ref=cm_sw_r_apan_glt_i_Q0K3BDH1R5NRM5WY5SC6?_encoding=UTF8&psc=1
I don't think it works that way but it would be nice. It horrid that there is this much homelessness going around but just got to look at our own government on why people are homeless.
Could you give more information on the Dave Paliadies pod cast.. Please...
I was doing about 1,100 miles a week. So time spans will vary. Mileage will vary depending city vs highway use. Now not as much for me either.
Kick in a bit more for the APPS Sensor... 3 pins are the rheostat. +5V APPS Signal GND Then there is 3 other pins which is the IVS (Idle Validation Switches) Idle Throttling GND Now the stock APPS has a tag value of voltage on the back which is the point the logic chip flips those two idle validation switches. Only one leg at a time will be hooked to ground. If the throttle side is grounded then the ECM follows the APPS signal voltage. If the idle pin is grounded then all APPS voltages are ignored and the Cummins Idle Software is used. Some time ago someone on CF posted about doing voltage adjustment to fix shift issues and such. This went down a huge rabbit hole that had all kinds of bad results. Typically the end user attempted adjust to exactly that voltage and the sensor would rock back and forth between idle and throttling causing all kinds of other issues, idling high, shift changes, possible error codes. Hence why all documentation on the stock APPS sensor says "DO NOT ADJUST". I've removed a ton of these crappy noise filters and ground wire mods even the dealer today still doing. I will give it to @W-Tthe ground wire mod does indeed work very very well. I just done one not to long ago with shift issues had the BD noise filter and the APPS wire mod. This particular truck would not shift to 4th gear period. After pulling all the wiring mods off and returning pure stock electrical now it shift into 4th gear normally. I even informed the owner I needed to do a W-T ground wire mod soon to keep this straight. I even showed him on my own truck of what is removed and how its wired. I done at least a solid dozen W-T ground wire mods and 100% success rate too. Always a solid fix and no longer AC noise problems. Now as for APPS sensors I would only suggest the Timbo's APPS being its a completely mechanical sensor and there is NO ELECTRONICS. Life pan of the sensor is about 7 to 9 years of daily driver. Do bother with OE replacement, or Wells APPS both of these are back to using electronics to toggle the IVS to idle or throttling and back to fighting with adjusting voltages and people always screw that up. Timbo's you can literally install, start and drive without even adjusting or doing a APPS reset. I know this isn't optimal but I know it can be done. The whole voltage adjust is all about that IVS switches only on Wells and OE APPS its critical of the voltage where on the Timbo's is actually the bellcrank angle voltage isn't even a issue. As you see there is no electronics and the angle of the bellcrank will set the idle or throttling IVS legs. This why you could install and forget and never think about it again. Just when you do the install as instructed from Timbos you actually setting the slack space from the screw stop so your closer to the breaking point of the IVS.
99 Dodge Caravan
Well I'm still on my way of fixing up my mini van. I just got my new tires for $380 installed and balanced. Really made it a better ride, smoother without the broken belt. So far I've only been running this mini van locally. Now with new tires I'm willing to travel now longer distances. No issues, no leaks, no performance issues. Just cheap tires but fresh rubber does better in the snow for control and just a bit better traction wise. Today I've got to haul out to Cascade ID let's see how it does.
Winter weather - What do you see where your at?
Dang. We could use more snow. Just been cold.
Weird I live in Idaho and never heard of this. Might have to start packing the 9mm more...
Yes the brass sleeves are the bearings in the turbo both my HX35W or HX35/40 Hybrid use the same kit. The snap rings hold the brass sleeves in places. One on each side I will warn the pin holes in the clips are very very small. Make sure to tool up before starting. Yeah my first turbo rebuild make sure you really pay attention to all the parts your remove and where from, etc. Me I forgot one of the pieces for the thrust plate and you couldn't tighten the compressor without it binding up. Again make sure you paying attention all the way through if anything doesn't feel right don't force it, tighten to make it bind up, etc. Look over everything again be sure all parts are installed correctly you don't need to damaged parts. When its done that turbo should spin smooth and be just a bit stiff at first but after ran a few minutes on the truck the bearings will settle in and spin much better. The worse part is getting the exhaust housing unbolted carefully without breaking the bolts off, then getting the housing to separate to expose the tubine wheel. I've tried a few others in my time to rebuild and few times I hit a wall and couldn't because bolts are frozen bad, housing rusted together, etc.
I've seen several auto Cummins do this too but out here you let it use the top gear like yours it would be building mass EGT's because of the constant grades. Very inefficient to run that low out here because it would always have to be lugging climbing 1% to 2% grade. Thankfully most of the ranchers and such all have manuals it the retirees that have the Auto's for towing there RV's and toys. I just done 2 clutch job in this winter already on a 3rd gen and 4th gen. Autos, are not very common out here. You still find out the EGT's drop lower up near 2k RPMs vs letting it settle to the bottom like those do. All you need to do is watch the live data of Engine Load and the EGT's will tell you a bunch.
https://www.amazon.com/Turbo-Rebuild-Holset-HX35W-HE351CW/dp/B07Y2L4P5C Please don't freak out and say you need a Cummins OEM or Holset OEM rebuild kit. Being I've actually order and used a Holset kit for my HX35.40 and DID NOT come with everything this kit has. That was the mistake I did I listen to everyone stating you must have the official Holset kit to make it right. Well Holset kit is missing all the o-rings this one has, missing the return oil gasket, manifold exhaust gasket, and the rear housing gasket. I HIGHLY suggest this kit over the Holset being its much more complete. As you can see the Cummins kit is short also.. No manifold gasket, no oil return gasket, no discharge o-ring, lots of missing stuff that should be there but Hey its OEM crap once again PLEASE DO NOT BUY! Holset or Cummins kits, not good...
Dirt to snow or snow to dirt.
Nevermind on getting tracks on a vehicle.
I know the feeling. I'm hoping for a bit of global warming. I'm tired of the single digit morning here.
