  1. Did you do a W-T ground wire mod? Not good to leave a battery out. I know these trucks will run on a single battery but the passenger side typically is the source of ground for VP44, ECM, and PCM. W-T ground mod would move it to the driver-side ground for the VP44 and ECM but the PCM is still on the passenger cable. No such thing as a rebuild PSG unit. It's either USED or NEW. Sadly rebuild PSG is a poor choice being that it most likely not calibrated to your pump. The other part is Bosch Certified Rebuilt pumps it is a REQUIREMENT to replace the PSG with a new unit and be calibrated on the test stand. Most likely a bad solder joint in the repair of the PSG and the heat is causing a solder joint to open up. Yeah, I've seen a ton of people doing transistor replacements and weird home repairs but did they ever calibrate the repaired PSG to the mechanical part of the pump? No. This where problems start.
  2. Mopar1973Man posted a blog entry in News
    Now subscribing members can see how much other members have contributed to the website. There are several badges that you can earn by just being helpful to other members.
  3. Mopar1973Man posted a blog entry in Thor
    I spent some time this morning tracing out the brake light function from the cab to the taillights. Then I found out the taillight loom I got from a 2007 will NOT work. It's a single taillight setup. Problem I figured out that there are two taillights in the wiring diagram and then started looking for the white/tan lead nope. Not there. Now I'm on hold, waiting to see if the salvage yard has a 2005 wiring loom so I can get the right wiring. The project is on hold for a bit to sort out the electrical for the taillights.
  4. SOLVED Make sure you get an 03 to 06 loom for the taillights. Funny part is 07 is single bulb taillight and 06 is a two bulb taillight with separate brake and turn bulbs. Already calling for 05 loom might be good swap at my salvage yard to do a swap.
  5. @Tweety Bird and I needed to run out and take care of a few things. I hopped in the shower and got cleaned up, and with fresh, clean skin and shaved, I started doing my makeup for the day. I did standard black makeup and wore my blue wig. Nothing fancy by any means but I've wowed another store worker today. @Tweety Bird and I stopped to get breakfast out, which I know of an awesome place for breakfast burritos. Old Towne Market has a small cafe in the back of the store. The gal working there I knew the gal at the counter; she took our order and handed the ticket back to me to pay up front. Ok. The gal at the till has kind of a blue-gray hair. I told her it looked awesome. She commented about my appearance. She was so intrigued about my appearance that she started asking questions then I revealed the cancer story somewhat, and she loved the fact I continue to do makeup and dress the part. Still, to this day, I get all kinds of stellar comments about my appearance. At another stop, I picked up a bit of fuel in Minnie. Now I'm pumping fuel in Minnie, and the older gent pulls in with a Ford 7.3L 1 Ton that looks awesome and is running great. Diesel man, I am. I gave him a kind comment about his Ford truck. I walked over after pumping my fuel and started a conversation about diesel dressed up as Titanium. This gent, being kind, basically stated strange-looking but hella knowledgeable. At that point, it didn't matter what I looked like, but the facts of my knowledge to help this old man fix up his 7.3L Ford floored him. I told him about his rear tires being over-inflated and how to fix it with my math formula. I showed him my phone from the website. Then I told him to consider replacing injectors because 176k miles is a bit long on factory injectors. He was very thankful I just happened to be there to give him info, This is why I don't care if I'm dressed up as Titanium, Mopar1973Man, or just Michael Nelson. I steal the show anywhere I go, any way I'm dressed. Titanium is my favorite way to be in public. No matter where I go, I'm always finding someone to just wants to ask why. Now, when the cancer story comes forward and the fact I lost all the hair on my head and found a way to enjoy life yet with cancer and still look good. Remember this is why I will be getting married soon. I met in the West Portico building in Meridian, ID, and had the luck of meeting her twice It was Suzanna who asked me for my phone number. There are just too many great things that come from my wonderful makeup work and the person I am! Would you stop doing this? Or would you be the one like me who wants to see how far down the rabbit hole this goes?
  6. Mopar1973Man posted a blog entry in Thor
    I had other running around to do today. By the time I came back home, I only had a few hours of daylight left before the shadows of the mountain start casting on the valley floor. I managed to get the filler neck installed and managed to cut the unleaded neck out to fit the diesel fuel nozzle at a fuel station. I was getting sore from lying on the ground to deal with that, so I shifted over to dealing with the brake light issue. Now I got power past the brake light switch still not making it to the taillights, so I've got more testing with a test light to find the issue. I'm so close to having this truck running so I can deal with repairing Beast that is nearly 500k miles and having serious oil leaks around the crankshaft seals, both front and rear.
  7. Update. I pulled the TIPM and cleaned off the board, looking for a bad circuit board tracer or burn. Nope. I cleaned the TIPM up and then reassembled and hooked it back up. I'm not sure why I didn't have power at the fuses, but now I do. Bad connection maybe? Now I'm tracing down the wiring hit the brake light switch and then attempted to check brake lights. Nope, Nothing yet. Now I pulled the brake light switch so the lights would be active. I checked at the pins power coming in and then the pin pressed in the light goes off. Normal working. Just to let you see the inside of a 2006 brake light switch internals. Now I'm at the connector at the fender checking for power for the brake lights, but I'm giving in today.
  8. Sadly Mark took care of it for me. The blower is under the passenger side but covered with another cover.
  9. I need a bit of help, possibly for the 3rd Gen TIPM, which on fuse 26 is my fuse for the brake lights. The fuse is good. Now with a test light I have zero power. If there is no power at the fuse then there must be a burnt tracer in the TIPM I'm figuring.
  10. I managed to get alot done today on Thor. Everyone was pitching in between Mark and Suzanna. We temporarily rigged up the AirDog fuel system so I could move the entire truck outside. I've got a trick I'm going to show on Thor that I'm doing for a AirDog soon. Already got the straw done in the sender basket. Then pulled Beast up with the trailer and used the a-frame to unload the new bed for Thor. Then, Thor was fired up, rolled out the door, lifted the bed up, and carefully lowered the bed back on Thor. I've got a problem with the brake lights not working, so I've gotta chase that problem quickly. I'm very pleased with the bed and the tailgate. The tailgate has a few minor dents, and then the bed has a few extra holes but is in good condition small dents. I've got more projects to do to this truck like sealing the radiator (another trick I wanna try). I've got an idler pulley for the fan belt to install. Then a full oil change. Then I'll have a working truck to use when I'm busy fixing Beast. What I figured out tonight just looking over wiring diagrams and quick test of power at the 26 Fuse in the TIPM and found both terminals of the fuse to be dead without power. I've got a post over on the forum...
  11. Yesterday, I got the electrical for the bed strung down frame. I have all new electrical running to the bedand taillights. Now I've got to get Mark to give me a hand and unload the new bed from the trailer to the frame of Thor. I'm planning on installing the AirDog 150 too. Today I've got to grab my old fuel pump I saved on the shelf and drill the straw through it and install. I've got a awesome idea of installing the AirDog in the bed side but I gotta look ar how much room I have after the filler neck is hooked up. Yeah I've got a gasser filler neck but its a 2nd Gen neck. Little work with a dremel tool I can open up that narrow unleaded to diesel sized nozzle hole.
  12. Error codes? Remember the engine requires compression and fuel for good power. Injectors could be spraying poorly, or possibly valve lash affecting compression?
  13. Quadzilla can limit power in different methods of tuning. Amount of advancement and when could limit boost pressure and drive pressures. Fuel map can limit directly but most just make linear ramp which is wrong. There is more than just dumping fuel or cutting fuel there are limits.
  14. Glad to hear it's working right after 1k miles.
  15. Mopar1973Man posted a blog entry in Thor
    A lot of things happened today. Actually, back up to last night, and I was making calls on getting a hold of a trailer to haul back Thor's new bed. Found a local friend I could borrow his trailer to bring the bed home. Yeah I have to use Beast one last time. Beast is leaking at both ends of the crank front and rear seals. I managed to get oil and an oil filter for Thor. Then, fresh coolant. I'm hoping to do a recrimp of the radiator here very soon. Back on track, I've got to haul down to Horseshoe Bend, ID to get the new bed. The gent that is selling the bed is a fan of the website too. Maybe I'll bring another new member to the website. As for the Website software, a lot is going on. I'm watching over many systems and trying to adjust for the best performance of the server and get the search engine walking the site again. I've seen some serious traffic changes in the amount of bots walking the site en masse trying to catch up to the new code and reindex several pages I had changed the URL structure in. There is much more coming. Like there is a solved marker now for the forums so you can be directed to the solution of the problem without having to read an entire long forum post. Gallery area: I'm going to ask for everyone to post photos of their trucks so we can have a Truck of the Month vote and then start replacing truck photos for the different generations on the website.
  16. Mopar1973Man posted a blog entry in Titanium
    I made a trip down to Nampa to my fiance's place. The next day I was hopping from salvage yard to salvage yard. I was on a mission to find the next bed for Thor. Even while I was out looking for a truck bed in the salvage yard I was still in hair and makeup. The fiance wanted to come along. She was wearing an orange dress to complement her I opted for the orange tone on my eyelids. Even the shirt which I don't need to repeat in text. You have no idea how much this really does bring more helpful people into my life. I ended up walking a total of 5 miles in 5 salvage yards. Now, even for huffing around in a dirty salvage yard, it turned heads for sure. Still in all the guys that work there are super helpful and could point out the trucks I was hunting for. Even on travel to another salvage yard, seeing other guys giving me thumbs up as I sit in traffic. Even fun to see granny rubbernecking with a smile.
