Bugman123
Everything posted by Bugman123
  1. Streets of Bakersfield, Ca.:biggrin::o
  2. What i have use and it work very well just watch out for the plastic stuff, if it set too long it will dull it, The Dregreaser is bought at "Smart & Final" retail stores (Store Brand). I mix it 50/50 w/ hot water in a 16 oz spray bottle. Spray on painted surfaces and other things needing to be clean and then use a cone tip on a water hose. You can reduce water pressure with a valve if needed. I usually spray thing down lightly every month or so, clean engines compartment makes it easier to see problems. I like to let thing dry for a few hours before running vehicle too. We use at work where we clean our pest control truck out at the end of each month on makes thing clean fast.
  3. 44 going on 29 again:wink: Not really into vids
  4. Have 2002 Ram (White), 1999 Accord Coupe (Red) , 1967 GTO (Candy Red), 1955 Chevy 1st Series PU (OEM green), His & Hers Suzuki 250 Quads:biggrin:.
  5. Thanks for all the info. Yesterday i started to look it over and found that the banjo fitting on the back of the pump was seeping:bang:. I guess when i had to get to the map sensor to put the Quadzilla Milage Max on, i moved the line a little:rolleyes:. I then tighten everything up and then looked for it to leak, but it wasn't:biggrin:. Used a paper towel to find where it was wet:2cents:. After that I degeased the area off took for a drive and then recheck. Checked out leak free.
  6. XPD Diesel Power for $126
  7. Ok today i was in a hurry and while my truck was warming up in the driveway I notice a puddle under the truck. It was Diesel and it looked like it was coming from the bottom of the lift pump. About evey 5 second there was a drip while it was running only. I took another vehicle and didn't get back intime to look into it futher. Question will these leak at the bottom? It looked dry above it. Anyone had this happen to them? Thanks in advance for any input.:confused:
  8. No one here has mention the use of Synthetic oils in the engine, transfer case and the diffs. This is a good Change the next time it is due. It will let everything work a little easier and and will last a little longer.
  9. Wally world is where i have bought batteries for the last 10 years and never had a problem with.. Good batteries and easy to get.
  10. Thanks for the response, gauges are next if nothing else happens around here. i was just wondering if anyone has the Max and what they got in an increase from it.
  11. I got a Quadzilla milage max this week and would like to know if anyone has been using it. i understand it is on some of the other Quadzilla programmers but i just got the Max. How much of an increase of MPG did anyone get with it. Also this is not to be used in California, Does it leave anything on the ECM so during the now smog checks will it show up after i have taken it back out? I will be tring mine out and will keep tab on milage.
  12. I just add my signature
  13. You got info don't you! Thank You Much for helping me out.
  14. It has always gone into 4wd but it that the light just would go out after 10 miles or so back in 2wd. The last time it did not come on at all!
  15. What am I to do next. Not Good time of year $$. Can the pod be replace or is there a lot more to it?
  16. That is what i have. Was under it eairlier todat and saw the the vacuum pod spuns about a 1/4" back and forth. it does not fell loose other the the spin. Is this normal?
  17. Don't know what you mean! CAD Let me do some research and see what i got.
  18. When I use the 4wd the light in the instrument panel has a mind of it's own. I am going into 4wd fine but when i first used it, the light wound not go out when i shifted back to 2wd, until i guess it shook whatever sender it has free (Gumed up?). The other day it didn't come on at all when i was in the snow in 4wd. Does anyone have any fixes or test? Thanks for any help. just want it to work the was it is suspose too.:confused2:
  19. Thanks for the info. I try it out. Did you use 1/4 alum?
  20. what do you think of Quadzilla Milage Max? says 8-12% increase in mpg!
  21. Thanks or the info. I found a filter for $30 so i think i might try it. Now to come up with a heat shield.
  22. Would any mod of the air filter assembly do any good?
  23. I think that i will do this to my 2002. i was thinking about an cold air intake, so i started to do a little research and found your info. No one has said anything about the fuel milage increase that they are getting. It makes since there would be some. Does anyone have any records of this?
