Everything posted by PilotHouse2500
Engine rebuild
FWIW, the engine is out and (for now) on the floor, but I doubt that would really be that much of the cost.
Engine rebuild
So, I got my first quote back for rebuild....erf...gut punch...Anyone have a recommendation in Minnesota for a rebuild? The first one back from the local Cummins rebuild is $12k+....or is that about right? Budgets need to know... Sorry in advance if this has already been discussed and I could not find it in a search.
Pilothouse/RAM3500 build
Well it was a busy night last night...I hope I didn't cut anything that can't be replaced as I had to cut a few things (throttle cable, fuel cut off cable and inter cooler lines)to finally free the beast!
well hello from the Cities...we get up there once in a while for Gopher games, hockey of course
I think I know of which town you speak of...mascot of a Beaver? Beautiful country!
I plan on using this truck to tow a trailer for 4 wheelers and also for cabinetry work I do on the side. The slotted and drilled disc will likely get swapped back for a more standard disc,
Well life likes to throw curveballs...a well intentioned neighbor/friend dropped me a Caraigslist add for a 96 that was being parted out thinking I'd look at the tranny for my swap. Well, the tranny was gone, but the frame and axels were still around. Now considering my 94 was used as a plow truck, the front end is RUSTY! Coupla thru holes in the frame even. Long and short of it it: I bought the rolling frame with factory paint on it (at least the front half), rebuilt axles and suspension. The front discs are a bit fancy and might have to get swapped out, but now I don't have to rebuild my axles and I can either sell 'em or keep for spare parts for "someday". Looking to move forward earlier than planned on pulling the engine and setting it on the "new" frame this weekend. So a few pics this week of that and hopefully Saturday of a cleaner frame in the shop. Tell you one thing about these trucks...they like to keep you guessing on what will be an SAE faster or metric! To top it all off for a great weekend of wrenching, a buddy came over and we were "just" going to put another wind on the pull start retract on my plow 4 wheeler...well found out the bendix is shot and I've now spent half a day so far trying to pull the flywheel (with no luck) so I can replace that!
axel swaps
well I drove out and looked at it all. I eneded up buy the whole rolling frame. The frame still has factory paint on it and not near as rusty (light surface rust only) as my 94. Plus both front and rear axles have been rebuilt about a year ago and he has the reciepts.
axel swaps
so I have an oprotunity, likley only today, to get a hold of the parts below for my project, Way better condiditon than all the rusty parts I have. Quick thoughts before 11AM CST? this is comeing off a 96 3500, looking to put on a 94 2500 frame. Dana 60 front axle 3:54 gears, fully rebuilt last summer, every single part was replaced, all lifetime warranty, all 4 balljoints, every tie rod, track bar, axle joints, steering stabilizer shock, drilled and slotted rotors and ceramic pads, rubber brake hoses. And alignment, $500 in new parts, $800 takes the complete axle. Dana 80 Dually axle 3:54 gears, with locker. Drum brakes. $450.
thoughts on stock ABS
follow my build thread and you can watch over the next few years as I get it all done...sorry won't be much faster than that...money is my driving factor.
well if I don't have an ABS light I won't have any coeds on my dash! It's been done many times on frame swaps I'm sure, I just have to make sure I do it right. As old as this is for ABS I'm sure it's not going to be TOO hard to make it go away.
well I learned how to drive back in the 70's so I should be good. Consider this subject CLOSED. NO ABS in the new build.
so just go back to old school (and remove it all) and know how to drive then?
So, now that I know the module is for the ABS on the truck...I'd really like to hear your thoughts on how well it works before I go through the exercise of finding a way to hook it back up or look for an alternate solution? I remember it was not all that great on my '93 Pontiac compared to more modern versions.
Help ID-ing these parts?
hmmm likely I should keep it then!
just what is on the part as shown in the picture
it was center console right above what I now know is the airbag controller. about where I have it in red below.
no pics, but last night got the bed popped free, and the rear cab mounts off. Cab wiring harness clear of the cab (still connected to the steering column). Fifth wheel mount removed. A few night off here for beers with the boys and a hockey game with the wife, but I'm hoping by Sunday MAYBE Saturday be down to the rolling frame!
thanks for all the help guys! Last night I got the connector apart: hey there's a bolt hidden in the middle of all those wires! insert popped out of the knob and: Hey there's a nut under that! Still wondering what that black box is I posted in the original question, doesn't seem to be consensus on that? Thanks!
Thanks! So, how does one disconnect the harness at the BIG connector near the firewall? I can see any flip/push tabs to release it from the part that comes thru the firewall. I likely will NOT be using the 94's steering wheel (but have yet to rule that out), since I will basically be changing the vehicle enough to have to ignore the airbag and any controls on the wheel except MAYBE cruise and wiper and WON't be using the gear selector on the column. FWIW, mine is 4X4 as well.
yah, no small set screw and I about tore my palms off trying to unscrew it....guess it's time for a tool with a lever...
There is a 12V wiper kit out there for the B series truck that is a drop in replacement for the originals. Doors, windows and possibly cowl vent will all be power. As for the tranny, the cost of the 6 speed itself is prohibitive, not to mention I have yet to find a drop in kit that has all the parts to hook to the '94 6bt. If you know of one let me know, the cost difference is a side wood project or two and worth it if it's not reinventing the wheel to mate them up!
found that, MUCH smaller and has verbiage on it to that effect. Biggest question, do I need this in my conversion project since I won't be using much, if any of the '94's cab related functions, just the powertrain/frame? I asked on my other thread, how do you get the 2WD/4WD selector stick knob off?
cool thanks! What does the "Centeral Timer" do?
