Everything posted by PilotHouse2500
Suspension measurements needed
tire size is relative. the measurement at the pivot on the passenger tire will set the reference height so I can adjust the other 3 for what tires I have on the frame. Thanks guys. Hoping to get this adjusted this weekend!
ANYONE?
OK guys need a little help here. Was looking at the body tongiht and getting it lined up when we thought about not having all the all weight on the frame will shift the suspension a bit relative to the frame due to the linkage pivot points. This would explain why some things didn't line up as expected. So I am looking for the following measurements from someone with either a 2500 or 3500 frame/suspension set up (6bt engine and manual tranny if possible!). Please note back where the measurement was taken from to the ground (center of bolt, top/bottom of bolt, joint between members, etc) something I can use as a solid reference. I plan on torching the springs to get it to sit where it should (putting bags in instead on the build). Thanks in advance! Note where the fingers are (should be 4 measurements). 2 pivot bolts on the arm, the pivot on the pitman and the pivot at the passenger wheel
Pilothouse/RAM3500 build
"new" fenders pounded "straight" and installed. Now I can make sure the fender is centered on the wheel and align everything and finish the cab mounts.
replacing or relocation intercoolers/rad
hmmm, you might be right....I got a bit cut happy taking it down... oops
Engine rebuild
I'll have to look tonight, I thought only 2 lines when to this beasty converting to manual...so... not needed for the TC...how are the manual trucks set up?
Engine rebuild
yah...so again, forgive the ignorance....what does it do besides drip all over since I had to cut the hoses off? I believe it to be part of the trans cooling system? I know it's not on our drawings of the 6bt...
Engine rebuild
since I've pretty much decided to do the rebuild myself, is there anything on the engine that's not needed that I can remove? Someone, somewhere, some forum said that I could ditch the device (sorry not up on what it is) that lives on the passenger side of the block? See picture.
well hopefully I've got enough room now up front for the intercooler and a new rad (if I can find a thinner one) and put some electric fans on to help assist ---> with the doghouse sitting on the frame now and losing the stock fan I have about 5.5 inches to play with. I still have to deal with the tranny cooler and the AC someplace.
Everyone post a picture of your truck!
suicide half rear doors like a modern 1.5 cab
- Pilothouse/RAM3500 build
so, sitting right here now. Need more eyes at some point soon to finalize where things are for sure.- Pilothouse/RAM3500 build
A little St Patty's day work. Cab is about where it needs to be, but will go down about 3".- Lets see who you are!
- replacing or relocation intercoolers/rad
kicked around ideas with the neighbor last night. Gonna remove the firewall this weekend and put the cab where it needs to be and pull the rad/intercooler and bracket off and line things up. 2 electric fans on the rad and move the intercoolers to between the frame rails under the cab is the plan. Maybe go to 4" pipes so the turbo lag isn't so bad since i'm going to REALLY be extending the pipes/hoses? Thoughts?- replacing or relocation intercoolers/rad
I already will have to cut firewall and let part of the engine live in the cab (COE now lol?) likely one cylinder. Too far back and the seat won't position in the cab right (too far from dash/lose space behind the seat/entrance and egress from the cab). Plus I have to deal with the front fenders landing in the right spot to stay centered on the wheel and still marry up tot eh front clip and cab right.- Manual Transmission measurements needed
from block right? thanks much! Just what I needed!- Manual Transmission measurements needed
So in my swap out to a manual, I'll need a few measurements to set my cab in the right spot (beyond where I NEED to due to body panel placement). Can anyone give me a quick and dirty measurement for the shifter and transfer case selector from the rear of the BLOCK? thanks!- replacing or relocation intercoolers/rad
So in my project, I need to find 5" of space on the front side of the engine. At a minimum that means replacing the fan with electric fan(s). The next big thing I'd need to move to get space are the intercoolers (turbo and tranny), RAD and AC pack. Potentially I can move some of that stuff to the side of the engine behind the head lights. I'm hesitant to relocate the RAD due to it's high need for fresh air. So my question is this: has anyone replaced the stock parts with a more efficient (and smaller) unit? If so, what did you use? any other thoughts?- Pilothouse/RAM3500 build
ok boys....feast your eyes....- Engine rebuild
yah that's what I was reading- Engine rebuild
So that being said, I did a quick search and lots of stands that SAY they can handle the 1100 pounds this thing tosses around...reviews say otherwise....any suggestions for a stand good enough to do a rebuild?- Engine rebuild
yah, at car (truck to me) club meeting last night I talked myself into doing the rebuild myself. Just need a stand for it.- Engine rebuild
well it IS Cummins and I know we have a premium on our stuff. I have not fired it up, I just pulled it so i can set it on the new(er) frame this weekend so I can start to get the body figured out. It hasn't run for at least 11 years and it DOES leak some oil, so a seal is bad someplace (could be as simple as the pan). I do have a bore scope so I could look inside and see what I see. I was hoping to rebuild and run for decades...I just want to see what it would be to have the work done so I don't have any questions about the engine later in the build or after I'm driving it. That's why I've looked at an estimate for rebuild costs...and the 12K sounds HIGH! - Pilothouse/RAM3500 build
