2002 Dodge Ram 3500 24v manual- Issues - Need Help Please!
Yes grid heaters cycle after truck is running, you can watch your amp gauge and see it.
Royal Squire started following 2002 Dodge Ram 3500 24v manual- Issues - Need Help Please!
Mr. And Mrs. Michael S. Nelson has occured!
Congratulations. Best wishes for the new year
Royal Squire started following Mr. And Mrs. Michael S. Nelson has occured!
Yoke Grenaded
Wonder if the transmission seized
Royal Squire started following turbo output to firewall allowable gap , Yoke Grenaded , Edit profile and 5 others
Edit profile
Thank you. I got it. Hard to see pencil because of photo. Congratulations on your upcoming wedding and cancer free status.
Edit profile
@Mopar1973Man-Mike can you tell me how to edit my profile. Can’t seem to figure it out. I’m using my phone. Thanks-Kitt
ECM or something else?
Could this be a starter problem since it starts so easily when rolling and popping clutch ?
Help with Quadzilla 3 cylinder/6 cylinder box
@LtkDoes the 6 cyl high idle work?
Been a little absent lately.
So sorry for your loss. Really hard when you have a great dad.
Is my grid heater dying?
Sometimes starter can be lazy and doesn’t spin fast enough.
Pilothouse/RAM3500 build
What I was trying to suggest is using the corners as in the 1st photo and drilling holes in rear for center 3 lights which would likely eliminate center rear stake pocket. I believe that most stake beds don’t have a center pocket anyway. Just my $.02
I’m recommending using the corner lights and duplicating that look with the three center lights. Worry about stake pocket later
Are you putting lights in the bed corners?
Aux Lighting and Negative Switching Advice
Can you share any photos?
@PilotHouse2500That sure is a nice panel. Did you form it with a wood buck?
Forced high Idle
In the 2nd gen if I understand it correctly the smarty can activate the high idle option without the VIN lock.
