Jolsen
  1. I need long travel air bags but they are extremely expensive
  2. yeah its sorta hidden but its a black 90* on the passenger fire wall
  3. I have been running the nations 180amp with the stock wires and fuse for 6 months no issues yet, nor do I expect any.
  4. I use red and tacky. and grease at every oil change
  5. my passenger went out at 215k. driver side is still ok at 223k...
  6. should fit. might rub a little but should clear
  7. Depends on what you want. pros and cons to both.
  8. What is the best wheel bearings out there for our trucks? I am thinking about doing them while I get my ball joints done.
  9. When in the Civic more lights blind me, then in my pickup or semi. I think most fail to remember alot of people are in cars and thier head is only 34-40 inches off the pavement...
  10. That is why some have mounted further back. The reflection off the hood will cause night blindness. I have a smallish 32" mounted to my bumper. It puts out more than enough for me. I might mount one in the headache rack when I get around to building it. Just as a work light/ get off my butt light for tailgaters.
  11. My 99 would max out and hold 28 psi on wot with the stock hx35w.and a 60hp program. All I had was an adjustable elbow. so I believe you have a leak or your wg is opening early.
  12. Yeah no reading on the plug ends...
  13. is that the Omega sign one? if so what should I see off the meter? I have been buying tools but electric still is a bit confusing lol.
