Tractorman
Joined
Last visited
Currently
Viewing Topic: P1688 with new VP44..help
Fuel pressure issue, works but doesn't.
Okay. Does the FASS lift pump use a relay that is operated by the ECM, or is the lift pump directly wired to the ECM? - John
Another thought - is the lift pump fuel pressure gauge electric or mechanical? If it is electric, does it have power when the bump start mode is used? - John
Overflow valve operation has little effect on lift pump operation. In the bump start mode the lift pump output flow is basically deadheaded against a non-rotating vane pump in the VP44. This is why lift pump pressure is usually the highest in this mode. Also, overflow valves rarely fail - they get misdiagnosed many times - but rarely fail. Since it is not mentioned, I will asked the question. Can you hear the lift pump running each time the bump start mode is used? While pumping into the bucket in the bump start mode, did you try restricting the flow to build pressure? If not, that may be worth a try. Is the lift pump being operated by the ECM directly, or has a relay been wired with the ECM operating the relay coil? I agree with @LorenS, it does not sound like a lift pump problem. - John
What shocks are you running and why?
I installed Bilstein 4600's front and rear about 140,000 miles ago. I have no complaints and the truck still handles well. I installed a Rare Parts track bar about 130,000 miles ago and so far it is doing what it is supposed to do. I have never experienced the death wobble or anything close to it. - John
Anybody Else Experiencing Global Warming?
Happened again this morning. This the third 5 inch-plus snowfall this week. I think this might be the last one - but, that is what I thought about the other two. - John
Holy crap moment!
I am thinking the same. The safety factor (working pressure versus bursting pressure) would be significantly higher with a steel line. - John
Fel Pro head gasket gave up in 4k miles
The first 106,000 miles was OEM coolant. Coolant was replaced with whatever Oil Can Henry's was using. The second coolant change was at 216,000 miles (Napa Long Life). Third coolant change was at 283,000 miles (Napa Long Life). Currently running that coolant at 363,000 miles. At 283,000 miles I installed a coolant filter. When I replaced the water pump at 216,000, I only did it as a preventative maintenance procedure - it was working fine. Personally, I think the quality of the water pump's bearing and seal diminished significantly in the early third generation trucks which led to failures of what had previously been a bullet proof product. I don't think the water pump failures were due to coolant change intervals. - John
Highly unlikely. Unfortunately, when the third generation trucks came out, quality control on some parts went down the tube - water pumps was one of those parts. I have three relatives that bought 03 and 04 trucks new. The OEM water pump failed (bearing failure) at just over 30,000 miles on one truck and well under 100,000 miles on the other two trucks - all bearing and seal failures on OEM water pumps. Sad. After-market replacement water pump quality is a gamble, as well. The second generation trucks never seemed to have that problem. I replaced my OEM water at 216,000 miles with a Geno's Gates water pump in 2014. The OEM water pump was still working fine - I just thought it was time. It is now my spare. The Gates water pump has logged just under 150,000 miles and is working fine. - John
Axle Wrap?
I agree. At least not on dry pavement. - John
Replacing head gasket
How long did you run the engine? Sometimes it takes a couple of minutes to remove the remaining air from the rest of the injector lines while it is running. Before I would pull any injectors or perform any time consuming work, I would remove the valve cover and start the engine. Don't worry, it will not make a mess. I would then observe every intake valve and every exhaust valve for full travel of operation. If any valve is not opening or only partially opening then you have narrowed down the problem. If everything is normal in the valve train, then I would crack each injector line individually while the engine is idling. If the engine rpm does not drop when an injector line is cracked, then that cylinder is not performing its share of the work. Test all six cylinders in this manner. Note which cylinders are not performing. This will not tell you exactly what the problem is, but it will tell you which cylinders are affected. This will save you some troubleshooting time and narrow down the cause of the problem. Sometimes the art of troubleshooting is not picking something that could be the problem and jumping into it, but instead, it is to methodically eliminate potential sources of the problem that are easy to perform with results that are conclusive. - John
Muffler - When to Replace
Now, that's funny!
So I guess, "Don't fix it, if it ain't broke." approach? - John
I am still running the OEM muffler on my '02. Just wondering when and if it should be replaced. It has logged 363,000 miles and has been in operation for over 20 years. It still seems to perform fine, but maybe it is one of those things that can slowly deteriorate internally and cause increasing back pressure without knowing it. Should I just keep running it or replace it as a maintenance item? Any thoughts? - John
No A/C after winter (worked last year)
Good, you answered all of the questions well. It is likely that the refrigerant charge is low. A rapidly cycling compressor would match the symptoms shown in your video. There is nothing wrong with recharging your AC system yourself. But, if you have never done this before, take time to watch lots of videos to get your best understanding of filling the system and the safety precautions to observe when doing so. Wear gloves. Liquid refrigerant vaporizes at atmospheric pressure at around 20° below zero F. It instantly extracts the heat from of whatever it touches. Also, understand that you do not know how much refrigerant or oil is currently in the system , Since you do not know that, it means that you do not know how much to add. The proper way to charge an AC system is to recover the refrigerant in the system, pull a strong vacuum on the system for a determined amount of time, and then check for leaks. If all is well, then the proper weight of refrigerant with the proper amount oil will be added to fill the system. I only mention this because when a person decides to add refrigerant themselves, that person assumes all of the risks associated with it. Before recharging, I would inspect the all of the components of the AC system that are visible for any oil residue surrounding them A particular candidate is the AC compressor dynamic seal. Let us know what you decide. - John
You need to be a bit more specific than "No AC" For example: * Does the ventilation fan work properly on all selected speeds? * Is the air coming out of the vents, but just not cold air? * Or, is the air coming from somewhere else (such as defroster vents) and is cold? * Is the AC compressor cycling. The vacuum supply to the HVAC selector operates various ventilation door positions to direct airflow to either the floor vents, dash vents, or defroster vents. If the vacuum supply is removed, the default ventilation door selection will send airflow to the defroster vents only, regardless of the position of the HVAC control selector. The vacuum supply has no input as to whether or not the AC compressor runs. So, if the AC system is working properly and if the vacuum supply was disconnected, the result would be cold air coming from the defroster vents. So, check out the system and report back. - John
Gooseneck hitch
Rear Seal for NV5600
We know you want the rear seal for the NV5600, but your signature does show which transmission you have, nor does it show whether your truck is 2WD or 4WD. I bought a rear seal from Napa (CR 19211) for my 4WD truck, NV5600 rear seal. - John
Dana 80-Yoke & Seal Info
Mine was extremely tight. I broke 3/4" drive sockets trying to get the nut off. Finally had to take it to a repair shop. The fellow said come back around noon and your truck will ready. I showed at 5:00 pm and all the mechanics had gone home. I found the owner in the shop working on my truck. I asked how it was going. He said he was still working on getting the nut off. We worked on it together for another hour and finally got it off with some rigging and the use of a 1" impact gun. I paid the guy a little extra for his perseverance. Be sure to check the axle vent tube for blockage as well. Sometimes a plugged vent will force oil by a seal. - John
Battery Load Test Using Starter
My neighbor has a 2011 Dodge Cummins truck. I would like to perform battery load tests using the starter for the electrical load. Is there a way to easily disable the engine from starting so I can perform the test? Has anyone done this test using their truck? - John
Bosch Alternator
Quite possible, however on the other hand, I am still running my OEM Bosch alternator with two brush kits and one set of bearings that I installed myself. Currently the alternator has logged 362,000 miles. Still on the original diodes. - John
Brakes - Check your hardware too
@Silverwolf2691, if you are the original owner of the truck and if you know that the equalizer adjuster along the frame rail has never been adjusted, then you are good to go with @Mopar1973Man's instructions. However, if you do not know the history of that adjustment, then I recommend to back off equalizer adjuster a fair amount before adjusting the brake shoes. This will ensure that the brake shoes seat on the anchor pin when retracted for proper adjustment. Then follow up with the equalizer adjustment. - John
Speed Round-General Questions
Probably. But, you should find out the total wattage and divide that number by 13 volts to get the amperage draw. I say 13 volts because it will never be higher than that at the bulb. The LED bulbs may already have the amperage draw written on them. - John I am guessing that there is a problem in that circuit. Those relays should last just about forever, especially with such a low duty cycle. - John
Low Boost After Boost Elbow Install
That's what I did. - John
Air Vent?
There are eight positions on the ventilation switch. @jlweldingneeds to give more information about the ventilation settings and where the airflow was going before the sudden change occurred, otherwise we are shooting in the dark trying to help him. - John
