JJK98CTD
Everything posted by JJK98CTD
  1. Check to see if you knocked off or broken vacuum line.
  2. Hello all, Wanted to give an update. I ordered a SO vp from JKidd at DAP. I started today removing items to get the pump removed. So far so good. I will finish removing the fuel lines tomorrow. I will be replacing all filters again just as a re-insurance. I changed them no to long ago. But what the hell that's a few extra bucks. I will give a few more updates as I move along. Thanks again for the help.John
  3. I Thank you guys for your replies. I have searched around. Will be making some phone calls to the vendors,with specific questions on the rebuild aspects. If they have new or repaired circuit boards internals etc.. The removal and install don't seem bad. Just making sure to clock the pump at TDC. I feel I can do it. I deal with keyed motor shafts quite often, being a commercial/industrial HVAC/R engineer. I will also ask one of my co-workers in our transportation dept for some help, being we have school buses with VP's in them. Maybe inquire to purchase the P-pump off of one of the buses with a cracked block. I will post up results and asked for help when needed.Thanks again,John
  4. Hello, all. Was out enjoying the day with the kids after work. Drove to the park. Went to go home truck started fine, drove away half way home truck died. Lost power, dead pedal and pulled off the road. I had 15-16 pound of fuel pressure, called my dad he brought out my snap on modus and recieved the gift of the P-1688 code. I tried to restart the truck after a min or two after pulled over. it wanted to start but didn't. I could here the airdog pump running when the key was cycled. Truck had been running fine. When i was home I varied fuel at the inlet of the VP. tried cracking injectors 1,3,5. but nothing. I trust the knowledge of Mike and the others on here the most. Not to bash the other sites. Now here's the question. Yes, I searched this out on the forums. Who do you guys in your honest opinion's would be the best vendor to get one from? I'm not running anything crazy, just a Edge EZ. I thank you guys for the help.John
  5. I had a similar problem with my Ford E-350 van. The heads are aluminum and the one spark plug blew out. When it did it sounded like a big block with no exhaust. Had the same spark plugs as in the Op's post. They need a special socket to pull them and have specific details on interval for changing I believe at 60,000 miles. When the day it happened I drove to the local Ace hardware for some stuff. everything fine. Came out fired it up and you would have thought I was staging up against John Force. I drove back down the road to my jobs garage, drove past a local garage and the mechanic ran out to see what the heck was going on. So I gave the Miss America wave and rolled on by. LOL! Anyway had it fixed heili-coiled the head and it runs fine to this day.
  6. I have a Snap on Modus. It's great and do alot of things. But for other stuff you need the DRB which was more then the modus. Good thing I got mine used. with a whole boat load of keys for other automobiles.
  7. Mine does it too. I have a Glow Shift fuel gauge and have a needle valve in line also.
  8. Just put a bid on it for a whopping 26 dollars. We will see in the am. Thanks, John --- Update to the previous post... Well I was the only one to bid. So I just one it. Final cost was 31.99 that was item and shipping. Should have in a few days.
  9. Cajiflynn, I might take you up on the offer. when are you heading up this way? Do you have family near me or will you be passing thru? PM me the asking price.
  10. Well since guys run the H2 rims. I wonder if the factory rims off of a duramax would work. I have acess to a set of them.
  11. Thanks Guys, I spoke to a buddy at work. Whom is a bus mechanic for the school district I work for we have a very large fleet of buses we own and service. I'm going to try to get a waste gate thru work hopefully at a better price due to the large volume of stuff they buy. Hope it works out. Also found this in E-bay. http://cgi.ebay.com/ebaymotors/New-Holset-HX35-Turbocharger-Actuator-HX-35-Turbo-_W0QQcmdZViewItemQQhashZitem3a622419a2QQitemZ250754636194QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_500wt_975 Thanks, John
  12. Hello all. Well I have been getting the turbo over boost code lately my wastegate is not rusted up. I tested to day with low air pressure. All I could hear was air hissing. It was coming from the actuators head. reached back and felt it. What do you guys suggest I replace with? Factory HX35 wastegate, turbo masters kit, banks big head or BD. I have no fueling boxes just stock truck with airdog 100 big line kit 5" exhaust. So blocking the wastegate would not work for me in this situation.Thanks guys,John
  13. Good deal, glad to hear you got it done.John
  14. Your welcome Heavy. Yes, But i would get both just in case and you could take one back.
  15. My bad sorry guys. 2- 1/2" and 2-9/16" were used too.
  16. I can go to the shop and get the size for you. I will try to get down there tomorrow.
  17. I believe it is (6 pt.) 2-3/38" That hub comes off and a theres a seal in the rear. It will take less then an hour to to. Might as well pull the diff cover and change the fluid. New fluid and don't forget the whale sperm (aka friction modifier). Good thing your pops works at the supply house.
  18. Well, if you are handy with a welder you could make one from a piece of pipe and weld a few tabs around to catch on a side of a bolt. Just a idea to throw out there. Heres a link for ya. http://quad4x4.com/Dodge%20Tools.htm http://quad4x4.com/Dodge%20Rear%20Axle.htm
  19. Hello, I just did that same thing on christmas eve at my buddies shop. replaced the seal on the passenger side rear. I have the LSD dana 70. So you need that giant socket and also you have to pull out the key way type pin that holds the seal. Make sure you clean that wheel and brake assembly with cleaner real well. Over all you have the easier set up to do. IT really wasn't that bad just make sure you get the correct seal. Good Luck, John
  20. Hello all, Hope all is well. I have the steel rims on my 98.5, but always like the nicer wheels that were on the 99 and up. I have seen the newer factory rims and tires on the trucks and they look great. I know they went to disc brakes but I have drums in the rear. I would rather have the older rims. Thanks,John
  21. I tapped mine at the light as mentioned. Being that the wires come from the headlight harness for the plow, and is right there. If doing a car alarm you can tap the parking light wire at the fuse. By the way we had a big snow storm that started late christmas day and lasted til 2 this morning dumping 12 to 26" so the plow worked great and I made some money. Thanks again.Good Luck,John
  22. Thanks Mike! Once again you are a life saver. I figured it out. Just to let people know the actual light socket is labled. Thanks again Mike. Happy Holiday's,John
  23. Hello all, I need to tap the parking wires on my 98.5 for hooking up my plow lights. on my turn signal / parking lamp the wires colors are. Green with Red trace Blk with Green trace Solid Blk I believe the green with red is one wire I need. Would Blk = ground then I can use th other wire with the blk with green trace. Thanks, John --- Update to the previous post... Got it all figured out. The plug socket is labled. Thanks, John
  24. Yes it is insane. That has been around for a long time. Just not talked about. How they work is you take a bigger soda/pop bottle 2 liter, Roll up a piece of tinfoil, long and thick enough to stuff down the bottle neck, to stay in place. When you use draino, or a emulsion cleaner I.E toilet cleaner. Pour it down the bottle neck, cap it shake the hell out of it. and throw it or place some where. Wait a few minutes the foil and cleaner start to react. and the gasses are being formed. The bottle will swell almost double or triple it's size, then it blows. It will literally shock you how loud it will be. It's like a modern day Molotov cocktail. Heres some examples. http://www.youtube.com/watch?v=ZU2ibQ6DEbs&feature=related
  25. Yes sir, Nice country up there. Especially this time of year with all the foliage changing colors. Nothing like New York State apples, And Genesse Screamers. LOL! We have a house up at Windham. I lived in Syracuse for a bit while my bro went to school there.
