Everything posted by Stanley
Rear sway bar end links
I have took both front and rear sway bars off for about 1 year now, seems a bit smoother ride for just back and forth to work. Towing with out them really sucks. So I have decided to put them back on and Im gonna need to find which links etc to get all the way around. Pretty much new everything minus the bar! So suggestions welcome!!! Taking them off was a pain in the *** I agree!!
Exhaust Brake Minimum Setup 2002 Cummins w/ Manual Trans
I wish we could put a system like that on our trucks! (2nd gen)
NV5600 Clutch, carried from t-case and trans build
No, it was IN or it was OUT haha... backing a trailer with it was a B****
So valair said that it is in fact a sintered iron sled pulling clutch... whoa. So I'm gonna have to get another clutch...?☹? Now I've had both south bend and valair but I'm stuck in which one I wanna go with.....
241DHD T-case rebuild kit
Thank you. I'm a neat freak, actual pretty cluttered and messy for me haha. The paint did work great though.
I've always had a dd clutch, and love them. This one was with truck when I bought it so I dont know the history on it.. I emailed valair and they said to send them more pics but they said it was a pulling or drag clutch and I dont do that anymore so I might get another one idk... need something smoother and good for pulling gooseneck around.
So along with re building my trans and t-case it was obvious that I needed to check to clutch out for wear and all that good stuff. So I did just that today. Snapped some pics to show yall. I have never had a sintered iron or competition clutch so I hope yall have some input.
Hard to tell in pics, but the "aluminum" color high heat paint looks really good. Turned out great! Pulled clutch today....?????? I'll make another thread on that lol.....
Little update, it's all back home now I cleaned, scraped, wire wheeled my little heart out... then put some high heat primer on it. I will put on some regular "aluminum color" paint to finish it off. If anyone is curious on what paints I used let me know. Now today I pull the clutch and check it over, make sure u can still run it... maybe I'll post pics of that later.
I also have 5in exhaust... I might have to get creative! Thank you.
well I got my transmission shimmed up today, wound up going back with same amount of shims as what came out. Hope my first trans rebuild lasts...lol Got pics of my fast coolers I'm adding also. Question though: which side would you put the filter kit on? Obviously the rotation of transmission would dictate correct? I also assume the "flap" would point up. Anyone ever install this kit?
NV5600 Rebuild and Shimming
If your in there do it all! Not worth just one or two. All Bearings and all synchros. This time I skipped doing the needle bearings. All bearings looked great but I got the whole kit and kaboodle so new bearings it got. I used this site and many others for the rebuild.
Thanks, yea I have all the tool goodies. Your idea for the counter shaft exactly what I was thinking. However I think the correct way might be by removing the tail housing. Maybe I can get away by not doing that?
So after I rebuilt my t case I rebuilt my 5600.....Whew what a job but its back together but Im having trouble finding the correct way to measure endplay on main shaft and counter shaft etc. Its all together minus the middle cover inside the bell housing. and I have new shim packs for both shafts. I might have went to far and might need to remove the tail housing to obtain correct measurement... Can anyone shed light on this method. I know what needs to happen, just not sure how to go about it lol. And I know specs are .002-.006 endplay. Thanks.
Just to update, wound up getting some parts through C & M Gear Works in Springfield, MO. Great People and always have everything on the shelf for t case and trans! T case is rebuilt all went smooth except when I took apart, then put back together then realized that there was no snchro ring or spings or detents from the previous owner!!! So went over and got those installed and its all back together now. Still working on trans.
Btw, americanpowertrainwarehouse Is closed permanently, and has alot of negative reviews and some pending lawsuits...just Google it. Lol.
Thanks that's great to know before ordering! The 5600 needs a rebuild 5 year grinds..synchros... I have alot of buddy's that can do that for me though. And may wound up doing it now since I'm almost there anyway...lol I wont take a chance and just replace the chain. It's not worth the gamble...
That's who that link is for, I havent dealt with them before but I soon will be... Their masterkit is what I'm probably gonna get. However I do not know if I really need the chain. I was looking at it last night, no visible wear or sharp edges, I just dont have any experience with chains to know "bad or good". I am a John Deere diesel mechanic "construction yellow" and know my way around everything pretty good but I have never dealt with chain cases. I have dealt with a np203 in a k10 but did not dissassemble. So what should I look for, or what tolerances/specs should the chain be in? Maybe I'll check YouTube for a video also... Thanks gents!
Well I'm gonna just get the whole kit prolly, I'll try and post pics and rate the whole experience for the next joe.
Check this out, Cummins Master Rebuild Might order one from these guys. Looks like it got everything in it! I dont know if I necessarily need a new chain but it's in there lol.
Pulled out my case last night to do a rebuild, where can I find the best kit for rebuild. I'm in this far so I might as well do deals and bearings. Need a complete kit-Please advise. On a second note, who ever was in there before used alot of rtv, and the pick up was pretty much clogged with it.??
