CUMMINSDIESELPWR
  1. TF did you use any shellac on the gaskets?
  2. this is the color i picked.
  3. one trick to prime is pack the oil pump with grease so it will pull suction. when i rebuilt mine i used assembly lube on the bearings and cam nothing more. a light coating of engine oil in the bore and on the piston skirt to aid in insertion. Hope all works well for startup!
  4. you could just use a pvc stub with a cap hose clamped to a short hose that is there.
  5. I have a rough procedure up and mostly completed, just need to put in torque specs and sequence of a few things and its done. this will get you from a bare block to an assembled block ready to go in the truck. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/26-engine-systems/481-24v-cummins-rebuild-step-by-step?hitcount=0
  6. ok rough article is up http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/26-engine-systems/481-24v-cummins-rebuild-step-by-step?hitcount=0
  7. working on building article now i figured out how to upload pics fast and now im just writing
  8. i have pictures of a full rebuild from bare block to finish that i need to make a article about. ill try to do it within the next week and half as i am moving to wisconsin for new job.
  9. try to get a mechanical oil pressure gauge installed to check to see if it isnt the dash gauge going bad. or a bad wire?if you are making oil, you either have injectors pissing (replace injectors) or the orings are very old allowing fuel to pass by like the said (easy fix)
  10. ive been running without a bracket for a long while. i know its there to support and such and eventually ill get another one as i dont know where the original went to
  11. i used new stock bolts from cummins, and i torqued per rebuild specs and pattern all the way to 90deg turn. was just curious if a recheck is needed and what ft-lb it is. If not then i wont worry. i dont go above 30psi boost and just drive it normally and not tow much so its an easy going truck
  12. So as the title states, is it necessary to retorque (ensure all bolts are up to correct ft/lb) the head bolts after break in and some mileage after full rebuild? So far i have about ~3000miles on my rebuild. I have had no issues but i heard rumors of needing to recheck torque on all head bolts. I am also unsure of what the ft/lb is to check for if needed. I did do proper install on head per rebuild manual. thoughts suggestions?
  13. i think i still need to do my write up on my engine build with pics it literally is step by step
  14. here is how they line up
  15. vp piston cooling jets vs cr cooling jets and direct squirts the vp piston coolers not only give coating to the bore but also aid in cooling the underside of the pistons and skirts. the cr piston coolers actually spray into a orifice into the piston especially on the bottom end of the stroke and also have the cooler nozzles as the vp pistons so they get twice the cooling ability.
  16. oh TF, i dont know if you have rebuilt stuff before but a head up on the wrist pin insertion... the tolerances are beyond tight to the point that its best to lube with machine oil and slip them into the piston by hand gently and slowly as they will bind easily until they align in the bore and slide in. be gentle as you dont want to score anything. Mine came pre assembled from the manufacturer so i just slid them half way out to insert rods. i did take one all the way out and kinda panicked that i almost couldnt get it back in lol.
  17. welcome DJ, ask as many questions as you want there are no stupid questions. this place is a great place to discuss and learn. I have never had an issue with anyone here!
  18. You can run a bolt through the chain for the rear bracket, it will be fine for just the head.
  19. thats some purdy stuff there!
  20. use the valve cover bolts to pull injectors. a small flathead crewdriver pulls the crossover tubes out easily with no damage. ive dont it many times.
  21. $6 for a complete set, they are retained in by the top bearings. cheap insurance get new from cummins and be good.
  22. its super easy to do, just take your time and ensure clenliness during assembly. i used a gas bath to clean my parts in and out before assembly.
