Remington92
Everything posted by Remington92
  1. Alright I turned it up to near 35 with no movement or leaks. There any good way to work on it without pulling the turbo?
  2. Ok dumb questions when testing a waste gate with a psig gauge is the point at which the waste gate open still 20 ish?
  3. I’m headed to test the waste gate at a buddies but I’m leaning towards map cause I’m pegging at that 36.84 running empty at 80mph. Also reading 22.34 psi supposedly on the OBDLink but we know that’s wrong
  4. Is it normal to get an overboost code on stock tuning? I notice sometimes when I get after the truck I’ll get p0234 and a freeze frame from the OBDLink 36.85psi intake manifold absolute pressure.
  5. Is there any issue using the stock fuel lines with mild injectors or should the whole system be upgraded to 1/2 line like in a fass?
  6. Not to highjack but how well do the pumps and belts hold up on these in nasty road environments? Curious if they’ll joke packing mud and snow around them.
  7. Sweet thanks! I plowed through that one and a couple more. I tried one of your formulas and another one of (a/6.89747)-25.something. Both hooked up and read zero at idle but would max at 2psi
  8. Gotcha! ill have to keep digging, seems like most the links to pdf and such in previous posts are dead now.
  9. now how do you change calculations within the app? Also I'm gathering the parts to do a BHAF install. Coming from powerstrokes its pretty standard to use a piece of 4" pipe as a coupler and then guys install the filter minder in the that section of pipe. I see on dodges most guys drill a hole in the end of the filter. Would one route be safer than the other or just 2 ways to skin the same cat?
  10. How far off is it typically? Couple psi or like 5-10?
  11. oh gotcha so im guessing an edge insight wouldnt be much use either since its an obd reader?
  12. Maybe Im being stubborn but id like to avoid putting in analog pillar gauges. I much prefer the clean look of having everything on one small screen.Do the quadzilla or edge insight/ juice guages read correctly?
  13. Darn ok, I was hoping to see some base health readings before throwing more power at the old girl
  14. Ok is there an app that works for gauges? I tried torque pro and it doesn't read boost or coolant temp
  15. How do these work with the grab handle in the back of the seat? *whoops never-mind didn’t see them in the edge of one of the photos
  16. Hey there I just hooked up an OBDLink to my 24v and noticed some strange boost readings. At idle I’m getting 12.4 and at full throttle about 22.4. Is this the app not reading boost correctly or should I be checking my map and wastegate? It’s an 01 HO
  17. Oh ok so not terribly bigger than my iPhone. As long as its got a semi low profile border frame
  18. Where is it planning to be mounted or is it still small enough to fit in the corner of the dash like most displays?
  19. Tuning in to see how this turns out, I loved my old edge insight CTS and how it was integrated into the pickup.
  20. Hey Mopar you don’t happen to have a shot of the Morimotos in the day looking at the pickup like your sport headlight pic? Curious how they’d look with the old man vibe of my tan and silver rig. Thanks!
