24vcumminspower
Everything posted by 24vcumminspower
  1. yep another for b&w the best i used went from reese 16k to b&w 18k night and day difference also used a friends 16k curt and B&W just kills them i love my patriot 18k slider
  2. oh sorry did not realize that smarty left in speedo calibration when returned to stock my apologies that is nice to know
  3. so you still have a smarty tune on your truck?
  4. Should be in between fuel rail and master cylinder for brakes ziptied up on firewall with wire harness with dummy plug in place you get it in and all hooked up let me know how you like it thanks
  5. I still have had no luck with getting vehicle selection on this thing even going to older version . Does it take a special connection to get vehicle selection? Just not sure why it wont work on this but has on others.
  6. ok ill work on that thank you
  7. the app version 1.9.43 works with the android 4.4.2 but the newer 1.9.45 does not from what i am seeing is there a way i can get the older version of the app to put on my device to use
  8. but I have other devices running that OS that work ok but they also have been on there a while also app states that it works with 4.0 and up just kind of weird trying to use android gps unit cause it comes on automatically with power just like a monitor
  9. loaded the app on an older android device running 4.4.2 and i only have demonstration in vehicle selection nothing else why could this be
  10. maybe a TIPM issue i know some of these trucks had issues with them
  11. Any updates on this monitor or when we may be able to purchase one @Quadzilla Power thanks
  12. timing may not be affected by it but i think fueling would be just like coolant temp changes fueling if your coolant temp is low your going to use more fuel
  13. also can check air intake temp cause i think that would contribute as well
  14. here you go hope it helps img001.pdf img002.pdf img003.pdf
  15. glad i could help and yes it is so much easier
  16. if you tap the throttle it will shut down is how the quad works
  17. I have a 2006 ecm/pcm pin out diagram of wires coming or going to ECM/PCM on side of block
  18. i was thinking also TV cable had that problem on my 01 did the same crap found a frayed cable was keeping the valve from returning all the way.
  19. @hdpwipmonkey Thank you so much for the info and checking that for me I appreciate it . Don't know why I thought it was lower
  20. OK well then engine load is right at same as TPS% if that is correct I thought that is why the old comp tune was set to start fueling at 20% because cruising was usually under that %
  21. I agree but same route I take all the time with close to same conditions and flat ground
  22. That would be great man thanks I appreciate it,
  23. OK guys looking to what you guys have for throttle position percentage reading at 70 MPH cruise with 3:55 gears and 47RE trans thinking mine is a little high from what I can remember but I could be wrong mine is at like 24-25% at 70MPH cruise I thought was usually around 17% before just can not remember??? Thanks in advance reading from quadzilla adrenaline
