Water Pump Finally
10 minutes ago, AH64ID said:
Go look....
It's almost at the top of the block.
I've got a 06 in the yard right now and its low on the block like mine. As far as I know the water jacket bottom is at the water pump. Like a lot of folks do is pull the water pump out to drain the block out because it is the lowest drain point for 24V.
:think:
There is no water jacket below the water pump through. If you remove the oil cooler the bottom of the jacket is right there.  Water pump is at the bottom... So for Dorkweed yes you would end up draining the entire system so you don't spill coolant.
