Quick change oil pan gasket mod.
  • 4 weeks later...
:iagree:
Ladder frames aren't bolted together for a reason. You would imagine that vibration and frame flex from normal operation will eventually erode the holes he drilled for the bolts. I see he went with good sized bolts but unless he significantly reinforced the holes and used bushings in the frame member to prevent crushing, that frame member is gonna move and create stresses in other parts of the frame. Depending on how long that truck is operational, I'll bet he starts seeing cracks after a while.
