- Replies 18
- Views 5.2k
Mopar1973Man 4 posts
Wild and Free 4 posts
Me78569 3 posts
mark402001 3 posts
If OEM lasted 450k then I would go OEM again. Hard to beat those numbers.
Already done...
Do you have any type of torch at all if even a hand held propane? I have had luck heating as much as I could that way if I didn't have access to an oxy actlelene torch, heat and beat and then let cool
I have an 08 2500 4X4 standard shift with 455000 miles on it. This is a work truck so no mods other than the deletes with the smarty sr. The front control arm bushings are shot. I am wondering if I should stick with oem or go to some kind of after market control arms? If I go after market what brand and where to purchase them? I just started to remove the drivers side lower and found the cam bolt froze up. I am fixing to invest in an air hammer to see if that will push it on out. When that back one just slid right out I thought this is going to be a piece of cake. Lol! Anyway if anyone has any suggestions I would appreciate them.
