- Replies 21
- Views 13.4k
Wild and Free 7 posts
leathermaneod 4 posts
Frankstein 3 posts
Dieselfuture 2 posts
Popular Days
I just did mine a couple weeks ago and undid both motor mounts then raised the motor almost to the firewall. I didn't have to remove the pickup tube, it was actually pretty easy.
I have done several over the years, one just needs to loosen the motor mount bolts enough to get the engine jacked up about 2-3 inches the mount saddles are slotted with a flare at the top I jack em u
Just loosen the mount bolt on each side of the engine is all you need to do. Just watch the fan to shroud clearance, there should be plenty of room but never hurts to watch it. Everything has enough f
Hello, I would like to know what I have to do for changing my engine oil pan? step by step! Also do I need to remove the trans.? Thanks
